Brembo Kit Arrives!!! =*PICS*=
"Also drilled rotors are today purely for asthetics. Removing material from a rotor is a bad thing as the rotor acts as a heat sink. Also, the drilling tends to promote crack propogation under hard use. In the old days, when brake pads got really hot (even race pads) they boiled and released their binding agents which created a gassy layer between the pad and rotor (think of an air hockey puck/table, slides prett easy when the air is on right?) this was known as "green fade." The cross drilling would allow the gasses a path to escape and prevent this type of fade. It was acceptable to deal with the cracking because the green fade happend more than the cracking so it was the lesser of the 2 evils. Today, on a quality OEM type pad, "green fade" is non existant so drilling serves no purpose except looks. Sorry for the long answer."
I remember a big debate concerning drilled vs solid. I'll try to find it. It was finally summed up with the conclusion that drilled looks awesome and SELLS well but does nothing for your car. Brembro or any other marketing co. website is not really independent enough to make an unbias conclusion. They are in the business of selling brake kits. I am most certain of this or I wouldn't post it. I'll try to find the link. Either way yur brakes look great and look better than solid in my o.
Again, #1 The Brembo Kit in this thread by badstang is first class. The below talks about rotor facts.
Ok Found part of it:
"WHY Blank rotors are better than cross drilled and/or slotted « » 11:35 AM 11/17/2005 Reply Edit
Ok I'm hearing a lot of conjecture, and people are STILL blowing money on xxxxxx rotors, so I will tell you all why blank rotors are better.
The reason for the creation of cross drilled rotors initially was to remove the "gasses" from the brake pads. HOWEVER, most of your modern brake pads (Axxis metal, AEM semi-ceramic) do NOT produce gasses when heating. This was on bad brake pads used in the 1950s and 1960s. Back then, asbestos was also used, and we dont use that either.
The other reason is so called heat dissapation. I don't have my physics and thermo books with me, but the logic is that the holes in the rotor are suppose to allow the brake pad to cool. So...air gets into the rotor from the inside of the vents. If you have a back rotor which is solid, air gets into these holes how? If your stopped, you are leaving air inside these holes sandwiched between the pads, thus creating air with a rising temperature. Its increasing in pressure from the heat, which I guess you "could" call a gas that would affect braking. So the cross drilled rotors do not remove any gasses formed by brake pads (because there are none created anymore) but could possibly inhibit the creation of "hot spots".
Cross drilled rotors have LESS contact area because of the holes.
But if the rotor is cooler, its better, right? Well no, because these rotors are not cooler. THe heat is generated from the pad/rotor contact. What removes heat the most effectively? When stopped or moving, the pad transfers heat into the rotor because its made of cast iron. the rotor has a lot of surface area and even vanes in it. But the little holes allow air in this surface contact, and you can transfer more heat into a solid big ass chunk of cast iron more than you can into the air. Don't believe me? Touch some steam at 150 degrees, then touch a piece of hot metal which is at 150 degrees. Which burns your hand? the metal. So let the heat transfer into the metal, because since it has so much more surface area, dissapates better.
Safety!!
Cross drilled rotors can crack! I have seen them!!
Even racing teams will reccomend AGAINST cross drilled rotors:
http://www.livermoreperformanc....html
Companies that sell cross drilled rotors that are redrilled may not be structurally sound. I have actually seen pictures of rear Integra rotors that have had hairline cracks turn into the rotor actually breaking apart!
Do your homework. Even Porsche and Ferrari will admit that the cross drilled rotors they use are for looks. So if you are one of those kids who thinks the little holes look cool, get a name brand drilled rotor like Ferrari does. The REASON Ferrari's 'holed' rotors are alright to use is because they are CAST with the holes in them, so they are not actually drilled into cast iron rotors. Cheap drilled rotors are not safe, and even the good ones are not necessary. Why do Ferrari do it? People THINK they want it, and it sells. If you don't believe me, go into the business world. You will learn that pretty soon, you can sell utter xxxx if people THINK its better.
Information I gathered from http://www.pdm-racing.com/prod....html
says:
"KVR Crossdrilled Rotors
Why should you upgrade to cross drilled rotors?
Simply stated, the function of any vehicles brake system is to stop the vehicle. This is accomplished by absorbing the kinetic energy stored in the moving vehicle, and converting it into heat. The friction caused by the brake pad rubbing on the rotor is the source of this heat. The more quickly and efficiently that heat can be absorbed and dissipated, the more quickly and efficiently the car will stop.
There are several contributing factors to this heat reduction. One of the most common sources of heat is from the gases produced by the bonding agents of the brake pad burning off. Under severe braking, this can actually produce a boundary layer of gas that pushes the pad away from the rotor, which can lead to excessive brake fade. The cross-drilled holes or slots in a rotor provide an escape path for these gasses (de-gassing or out-gassing are common terms), and allow the pad to stay in contact with the rotor. As well as de-gassing, cross drilling or slotting will provide better wet weather braking as water is swept through the holes, or down the slots.
A vented rotor can be viewed as an air fan. When in motion, the vents draw air from the center of the rotor outward. This air flow, over an increased internal surface area, effectively dissipates rotor heat. Cross drilling adds to this air flow, as well as providing additional rotor surface cooling. "
This company is just telling you that the rotors may be cooler, however they fail to mention that the holes really do create a more than substantial decrease in surface area, thus less braking, thus less heat created, thus the less heat CREATED will leave the rotors cooler, the holes barely do anything! Its the less braking lowering the temperature!
Slotted rotors-
Find me a company that uses stock slotted rotors. They remove brake dust, but if you study braking systems, you find that with modern cars, flat blank rotors and semi-ceramic pads, the brake dust causing the rotor to slip on it is almost non-existent. But the brake dust doesnt need all those lines. Notice how most front brake pads (and most back) have that line down the middle to give essentially two bite points. If OEM or racing companies found it to be a benefit, they would do it.
PROOF OF IT ALL:
Find me an F1 car as of now that uses cross drilled or slotted rotors.
They all use full ceramic rotors and ceramic pads. Are they drilled or slotted? No.
If they helped the fastest cars in the world, wouldn't they use them? Its basic calculations that show the lack in surface area does not make up for the possible loss in temperarure. They use brake cooling air ducts insted. EDIT: This is false, the rotors are made outta something different and would blow apart with holes : End EDIT
BIG BRAKE KITS:
Some have asked if the big brake kits are worth it. This is sort of a relative question, but the simple answer is no. Regarding the big ones with drilled rotors, if you know that they are cast that way, at least they wont crack. I will still advice against them.
[Edit: ricer cars but principle is same]
In terms of a big brake kit, I have seen some for Civic DX models. Civics have the small pad, small caliper, and a 9.5" rotor. The big rotors are 12" in diameter, ok so the overall diameter is close to that of an Acura RL (1999). But the sweeping area (the area that the pad can grab) is still the same if they use the same caliper and same pad. If you have the same pad and caliper, you are using the same rotor surface, just farther out, so it will increase braking from stock. However, if you were to change knuckles, etc, and get Acura RL caliper (larger piston than your civic DX piston), RL pads (much bigger and taller), and RL rotors 11.8" but much more surface area is touched, then you have a better brake setup because you have OEM parts, and a better grip on more area of the rotor. The downfall is added weight (since big brake kits are usually 2 piece and lighter) but the benefit is that you have so much more stopping. Ok, so the big brake kit will have less unsprung and rotational mass (so a little better accelleration but less braking), but they tend to run over a grand, and you can use OEM parts to build a better setup for half that.
IN CONCLUSION:
Don't buy slotted or cross drilled rotors, blank are better, and stop better. Physics people, get me my formulas and help me out here.
If you must get rotors with designs on them, get the slotted ones by a good company, and DON'T get blank rotors redrilled with little holes all over them. IF you absolutly must have the rotors with holes cause you like em, get them from a company that casts the rotors like that. I have seen rotors break and this is for your safety!
REMEMBER......
Your car will only stop as fast as your tires will allow. All the braking in the world wont work if your tires are bald and on ice!!
Thats what I said...:D
Also, those $3000 brake kits use 1.25" by 13" or 14" rotors, the cobra rotors that come with cobra brakes and the cobra r brembo kits are 1.1 by 13" so there noticably thicker (.15") than the stock style rotors and the cooling vanes down the center are smaller which also adds material. In this way, the cross drilling doesnt affect them as much. Plus you get the added benifit of selling your product not only to racers but rich people who think it looks cool (which is actually a bigger market than the racing one). Most places dont stock plain rotor brake kits because they dont sell well, but if you have them order a kit or get one direct from the manufacturer you can get it in plain. Thats how I got my BAER 13" rear brake kit with plain rotors.
I have been told that they dont even make the cobra R brake kit in plain rotors anymore because it didn't sell well. Thats why I'm trying to get just calipers so I dont have to part out the whole kit for just the calipers (I dont need the brake hoses and dont want the rotors or pads).
Oh and mustang6tee8...I dont think you got a bad deal. The brembo kit is about $1000 for the front and its so cheap because it uses OEM (granted there 2000 cobra R and regular cobra) parts, so theres no extra engineering, caliper brackets, etc.etc. to fab up like SSBC had to do with your kit. I wouldent be upset at all if I were you, you didn't get shafted.
Sorry if were derailing your thread here badstang.
