  • SN95 4.6L Mustang Tech
Broken axle studs!!
  • Thread starter Thread starter btmain
  • Start date Start date Oct 21, 2010
btmain
27
Virginia Beach, VA
Oct 21, 2010
  • Oct 21, 2010
I have a friend with a 2000 GT who had a flat tire. I dont know how but in the process of replacing the tire broke two of the axle studs clean off! How do I go about fixing this? Do I have to replace the whole axle shaft or just the studs? And if it's just the studs where do I get them? Any help would be greatly appreciated! Thanks in advance!!
burnthelight88
Active User
Oct 21, 2010
30
Pittsburgh, PA
Oct 21, 2010
  • Oct 21, 2010
Wheel studs...available at any auto parts store, rather cheaply. You only need to replace as many as you have broken, so 2 in your case, and they typically just hammer out and in to replace them, but I haven't had to do it in my mustang yet. I've done it in quite a few GM's at the shop though
twogts4us
4,188
12
79
Dunedin, FL
Oct 21, 2010
  • Oct 21, 2010
Burnthelight is spot on - this is a cheap and easy fix...if you don't want to do the labor any tire shop can fix you up rather cheaply as well, but you'll pay their labor of course.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 21, 2010
  • Oct 21, 2010
I'd personally replace them all, on the affected axle. If they were stressed enough to break some, the strength of the others may be compromised, too. Studs are cheap, cars are not.
burnthelight88
Active User
Oct 21, 2010
30
Pittsburgh, PA
Oct 21, 2010
  • Oct 21, 2010
Yeah, good point, I was coming off a night shift when I replied...when I had to do this on my Buick a few years back in my driveway, I just replaced all the studs for that wheel, and eventually all 20 got replaced.
btmain
27
Virginia Beach, VA
Oct 22, 2010
  • Oct 22, 2010
Awesome! I have access to a lift so it will be real easy! Thanks alot! I didnt think they would be that much or that hard to replace but just wanted to make sure before I rip into it! Thanks again!!!
ChillPhatCat
20+ Year Stangneter
Apr 22, 2002
409
65
48
Syracuse, NY
Oct 22, 2010
  • Oct 22, 2010
Prior to having lost a wheel at highway speed in my IROC I would have disagreed with you, but... well... I now belive that this is a good idea to replace them all if you replace one.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
