Help - I am new to this board but I was hoping for some advice. Just put on a procharger, had it tuned and went to the track. Ran twice and on the third run, clutch started to slip (Stock on there now). On the fourth run something broke. Something in the rear...not sure what yet, but something....Worse case i will need to replace the diff, gears, axles, clutch....and while i am in there figured i would put in a flywheel....
What I want to know, what do i get? I have no clue on the diff, but i was already running 3.73 gears. For clutch i was thinking Spec Stage 3+ and Spec alloy flywheel.
Help???
Help???
. 31 spline t-lok(termi diff) with 31 spline moser axles, FRPP 3.73, and motive master bearing kit. Its not a monster of a rear but it'll handle the power your putting down. Also it wasnt that expensive.
