Broken front seat mount
Sorry if this has been covered before, I did search but came up with nothing. Now the problem. The front left stud for my driver seat has ripped out along with the sheet metal that retains it. Does anyone have any suggestions on how to repair this other than welding in a new piece? Thanks.
You will have to reinforce the area. The only way to reinforce it is to weld a new plate or install through the floor subfrace connectors. Bolting a seat to the sheet metal is like using a wood screw to hang a person from the Empire State Building. Eventually it will let go and disaster is the result.
Is it the threads that are stripped? Or is it the hole mounting area is torn out?
I think you mean the whole thing that retains it. If so it is you would need it tig welded back down.
i have a similar problem, but it's just the bolts that are broke on my seat, also both of the left side bolts are broken. So when i step on it, i have to hold the wheel nice and tight or i'm in the back seat.....gotta get this fixed..
No. The actual brace/bracket whatever you call it still remains. The sheet metal around where the stud screwed into ripped out along with the stud.
I had 2 "L" shaped pieces fabbed from 16 gauge steel. I set them down on the existing channel so that they made a "[". Then they were marked and trimmed for size and fit. I drilled the stud holes and used a 3/8" fine thread aircraft nutplate in place of the missing stud. Then I used Cherrylock rivets (high strength aircraft blind rivets) to secure the new "[" shaped section in place.
I used aircraft rivets instead of welding because the end product is stronger and I don't have easy access to a welder. If anyone has any doubts about rivet vs. welding, try and find a metal airplane that is all welded. You won't find any.
If you have access to the proper tools, my fix will be really simple. If not, then maybe you can modify it to work for you. Instead of using a nutplate, you could tack weld a bolt in place of the missing stud. If you could find some steel pop rivets that did not pull the stem out when they set. You could use them in place of Cherrylock rivets. The rivet stem needs to stay in place to give strength to the rivet. The stem in the rivet makes it solid and not flimsy and easy to shear off.
It may be that welding the "L" shaped pieces in place one at a time would work. Cut and fit one "L", drill the bolt hole and the weld a bolt in the hole that is for the missing stud. Then weld it in place. The repeat the cut and fit of the next "L" and weld it in place.
