Broken Intake Bolt
  • Thread starter Thread starter onefstsnake
  • Start date Start date Nov 18, 2006
1 of 2 Next Last
onefstsnake
792
Northern VA
Nov 18, 2006
  • Nov 18, 2006
Well one of my intake bolts sheared off into the head.
I bought a bolt extractor but the broken bolt split and is now stuck deep in the head.
Its the passenger front bolt.
Im wondering if I can just leave that broken piece in there when I put the new intake on and leave the new bolt out???
Either that or I need to drill and tap the head to accept a 3/8" bolt...
BadAndy
766
Ohio
Nov 18, 2006
  • Nov 18, 2006
myself ,I might take the head off and too a machine shop
onefstsnake
792
Northern VA
Nov 18, 2006
  • Nov 18, 2006
id really rather not. since some of the intake bolts broke Im afraid some of the head bolts will break as well...
Plus I would need new gaskets and crap.... I hate working on this damn car sometime...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 18, 2006
  • Nov 18, 2006
Pull the head and take it to a machine shop. The head bolts are unlikely to break since they are much stronger than the manifold bolts.
Leaving the broken bolt in there will cause a leak. You could get water in the oil. That will kill your bearing in short order.
R
Robs96
131
  • Nov 18, 2006
This saved my ass once, so maybe it will work for you. I broke a bolt down deep once and I used a small punch and a hammer and painstakingly chisled enough of a groove that I was able to use heat and a flat head screwdriver to work it out. I don't know without looking at the car or seeing a pic of the spot but it might be worth a try.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Nov 18, 2006
  • Nov 18, 2006
Definately don't just leave it out, you'll be in for all kinds of trouble then just like jrichker said. Also, you won't want to drill and tap it to a larger size because torque will no longer be even across the intake. I'd definately try Robs96 idea before taking the head off, but you must be careful not to screw up the threads.
onefstsnake
792
Northern VA
Nov 19, 2006
  • Nov 19, 2006
Well I came up with a new idea. New to me atleast.
Drill the broken bolt, then tap it to 1/4" x 20. Then JB Weld a 1/4" x 20 bolt into the broken bolt and hope I can just ratchet it out.
8950HO
658
  • Nov 19, 2006
The intake bolt`s are 5/16".
If you leave that front passenger side bolt out,you will likely have coolant leakage.
R
Robs96
131
  • Nov 19, 2006
Can you remove the intake and use heat and some vise grips to remove it? You should still have somewhat of a stud left after taking the manifold off. This maybe the only thing left to try. I'm not too sure about the JB weld idea but hey, if it works let us know. How did you shear the bolt head anyway?
onefstsnake
792
Northern VA
Nov 19, 2006
#10
  • Nov 19, 2006
  • #10
the bolt sheared nearly flush with the head.
It broke because its a 13yr old Ford. lol
Daniel50
716
Discovery Bay, CA
Nov 19, 2006
#11
  • Nov 19, 2006
  • #11
same exact thing happened to me and same bolt. i ended up getting new heads haha
onefstsnake
792
Northern VA
Nov 19, 2006
#12
  • Nov 19, 2006
  • #12
Well I have an extra set of E7's but Id really rather not take the heads off.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 19, 2006
#13
  • Nov 19, 2006
  • #13
can you place a nut over the broken bolt and weld the nut to the old bolt
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 19, 2006
#14
  • Nov 19, 2006
  • #14
I mean like fill the center of the nut with weld till it's part of the old bolt...I do this alot but I would need to see a pic of what your talkin about
EMW150
2,020
Roaring Spring,PA
Nov 19, 2006
#15
  • Nov 19, 2006
  • #15
This happened to me on two different cars. Both the exact same bolt. Passenger side front. I repaired both with heliocoils without removing the head. Remove the intake. Stuff some rags in the lifter valley under the seized bolt and tape off your ports beside the bolt. Centerpunch the seized bolt and start with a small bit to make a pilot hole and then go bigger. Gotta make absolutely sure you stay straight when drilling. What I did for the final drill size was I temporarily reinstalled the intake manifold and made like a spacer that fit in the manifold bolt hole and made the bit fit tight through the spacer to keep the bit completely centered and straight. Then tap and thread the heliocoil, shopvac everything out real good and your done. Worked great for me in both cases.
stang&2Birds
2,091
New England. :-) CT/MA
Nov 19, 2006
#16
  • Nov 19, 2006
  • #16
Finally, it's about time someone suggested the way that a shop would handle the problem!
I LOVE reading posts about slotting the bolt and welding to the bolt. IMHO, if slotting the bolt then allows you to take it out, get a clue and remove the bolt in the correct direction in the first place. Welding is often NOT an option. And, I would NEVER suggest a newbie welder try it.
Why remove the head? That's a ton of work! Get 2 rolls of paper towels, STUFF every hole. Put cloth towels over the paper towels, drill the bolt (use a vacuum cleaner near the drill if you have an assistant), and put in a heli-coil. A heli-coil is more than strong enough to hold down the intake!
See:
Heli-Coil Install. Olds Quad 4 head example.
http://www.veryuseful.com/GM/tech/heliCoilInstall/
You can see that I used ~$1 of Duct Tape to keep the shavings out of the head. Ohhhh, a whole $1 of Duct Tape! I guess using $1 worth of duct tape is too expensive and too much work for some people.
onefstsnake
792
Northern VA
Nov 19, 2006
#17
  • Nov 19, 2006
  • #17
I drilled the broken bolt out and tapped it to 1/4 x 20 and coated a matching bolt with JB weld. Should come out now.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 19, 2006
#18
  • Nov 19, 2006
  • #18
I did the same thing. Those bolts are suseptible to breaking since after time coolant leaks by them and corrodes them and they snap. It would be a good idea to coat the corner bolts of the intake in silicone when you replace them. Another option for getting the bolt out is to weld a nut to it and use a wrench to get the bolt out. Welding to a broken bolt puts huge heat through the bolt and it breaks up rust or whatever is causing it to be stuck. I have done this many times and they always come out.
T
tripleblackragtop
12
Royal Oak, MI
Nov 21, 2006
#19
  • Nov 21, 2006
  • #19
Broke the same bolt, doesn't appear to be uncommon. After unsuccessfully trying various chemicals and extractors I ended pulling the head off and drilling the bolt out from the backside. The other end of the bolt is concave so a drill bit won't be dancing around. The rough edge of the broken end really didn't allow starting to drill it out from the top side.
Start with a very small drill bit, and progressively step up to larger drill bit sizes. As you get closer to the edge, you will be able pull the remains of the bolt with a small needle nose pliers. You might need a small punch to try to get the remains loose. Tap it lightly as if you were trying to turn it. Or try using a flathead screwdriver to try to budge it. Using the needle nose to bend the bolt threads way from the head will also help as you get close to final extraction.
Run a thread chaser through to clean up the threads in the head. Buy a new bolt. If you're worried about thread engagement, you might be able to use a longer one at that position. Use a little anti-sieze.
onefstsnake
792
Northern VA
Nov 21, 2006
#20
  • Nov 21, 2006
  • #20
Yeah Im just gunna pull the head...
What all needs to come off? Header, pushrods, rockers...
Also whats the torque setting on stock rockers/heads?
1 of 2 Next Last
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
