  • SN95 4.6L Mustang Tech
Broken Motor Mount
  • Thread starter Thread starter SFC.Kill
  • Start date Start date May 5, 2009
SFC.Kill
55
Parker Ford, PA
May 5, 2009
  • May 5, 2009
My right motor mount is broke. Is it a pita to replace? My Haynes says to remove starter.
J
jomull55
202
lucas, OH
May 5, 2009
  • May 5, 2009
im sure it will be a pain to swap. but i wouldn't remove the starter. id get at it from the front if you can get around your a/c. im not sure if thats in the way because mine is gone. maybe just swap to a tubular k while your at it?
bboylobo
130
Lancaster PA
May 5, 2009
  • May 5, 2009
might be a pain. you would have to take off the starter unbolt both motor mounts with a 21mm socket and breaker bar. and lift the engine with a jack and block of wood from the bottom to get enough clearance.
squeak93
2,348
417
164
Joplin, Missouri
May 5, 2009
  • May 5, 2009
+1 on pita. Might have to remove the ac if its in the way... I don't have it anymore and would think its in the way.
Starter does have to come off... Pray there are only 2 of the 3 bolts as the top one is really hard to get to.....
bboylobo
130
Lancaster PA
May 5, 2009
  • May 5, 2009
top one on the start is a PITA. i would think you can get it with a combination of a unibit and some extenstions. Dropping the K-isnt would give you direct access but its alot of work . Best to do some headers or replace the k with a tublar one while its down if you have the $ to do it.
flstang65
1,484
135
94
SE Georgia
May 5, 2009
  • May 5, 2009
The top starter bolt, once removed, does not need to be reinstalled it. I havn't put mine back in and it has been over a year with no problems. To get the top one out, what I did was; take a stubby wrench, place the box end on the bolt head, use a chain and drape it over the open end of the wrench, and pull down.
squeak93
2,348
417
164
Joplin, Missouri
May 5, 2009
  • May 5, 2009
You can get to all the bolts from the front of the motor with lots of extension and swivels. the bottom two you go through where the motor mount lower nut is on the k member the top on you go up BY the motor mount above the k member. Expect you fore arms and fingers to hurt b/c of the way you have to contort yourself to make this work. God forbid one strips. The middle bolt on my starter was stripped and I spent 5 hours getting my starter off. On a side note, sears has some bad ass bolt outs that are 3/8 drive and are slim enough to get in there. 20 bucks for the full set (starter and expansion set). Best investment thus far.....
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
May 5, 2009
  • May 5, 2009
I have done this before. I installed poly mounts on mine.
You MUST remove the starter to access everything on the passenger side. Rempove the starter is a PITA so get some extensions and a universal joint.
When you lift up the motor to remove the mounts, jack off the bellhousing
use lots of WD40
SFC.Kill
55
Parker Ford, PA
May 5, 2009
  • May 5, 2009
Thanks for the replies, So I have to remove the starter and just unbolt the left side motor mount from the engine just to replace the right side.....crap.....might as well change both MM's while I'm at it. Dam I just did a PI Swap too and I didn't notice. It would have been alot easier.
G
GTtopLESS
79
#10
  • May 5, 2009
  • #10
I fear I have a busted mount also...although I like to do everything myself, I am considering having a shop do it. What do yall figure..3 hours of labor?
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
May 5, 2009
#11
  • May 5, 2009
  • #11
first time will take you about 8 hours
bboylobo
130
Lancaster PA
May 6, 2009
#12
  • May 6, 2009
  • #12
i shoulda replaced mine when i had my kmember down last week oh well
didnt think of it
G
GTtopLESS
79
#13
  • May 7, 2009
  • #13
eight hours for a first timer I guess your saying, but how many hours would a shop charge? are you all replacing with poly mounts or just using factory replacement?
d98gt
4,505
59
204
SE Texas
May 8, 2009
#14
  • May 8, 2009
  • #14
Shop will likely charge around 2 hours
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
