- Jan 30, 2007
- 50
- 0
- 0
I am considering swapping in a 66 ford Bronco 9" limited slip rearend into my 65 mustang.
I have read through a few posts regarding this swap, but I still have a few questions.
1. The axles have the 5.5, truck, bolt pattern, so that is a problem.
If I redrill the correct bolt pattern, will the larger axle flange impact my choice of brakes?
2. The axle sizes are 27.25 Left and 29 5/8 right (28 spline). If I get new axles, I think I could use a 93-97 or 99-2001 ranger axle for one side (27 1/4) and perhaps a 79 - 86 mustang (29 1/4) or a 94-98 mustang (29 15/16) for the other side. These axles will be from a 7.5 or 8.8 rear. Should I take into account the c-clip groove? i.e should I cut off the c-clip area of the axles. If so, I will need to consider slightly longer axles to compensate for the length I am going to have to cut.
3. The different axle lengths reflect the pinion offset. Will this offset cause any problems as far as clearance?
I understand that the perches are on the wrong side of the housing and will need to be relocated.
The housing is almost exactly the same width of a 65 rear and this housing has the small bearings, so that is a plus.
