- Stangers,
I have a 2001 Mustang GT with 92,000 miles, SOHC that has a bucking problem. The sympton: After warm, cruising at 1200 to 1300RPM, 40 - 45 MPH the car, when pushing gently up a hill or on the accellerator produces a bucking, almost a skip in what appears to be the ignition.
What's been done:
- I have replaced the transmission fluid and filter (was never done)
- replaced fuel and air filters
- Replace all spark plugs and all coil over plugs
- PCV, (which I'll check for vacume and voltage);
- or something I noticed: 2 of the red rubber insulators that sit inside the sockets of the EFI connectors are missing. Maybe thay are somehow arching, but I don't know.
- TPS not working correctly, but that should through a 122 code and I have no codes showing.
Does anyone have any ideas??
I appreciate it, thanks!Bob
Issue was bad wire!! If they are all that easy....thans everyone. I did check compression, EGR, and leaks! all good
