  • 1994 - 1995 Specific Tech
buckling when under load
  • Thread starter Thread starter fordtech28
  • Start date Start date Nov 20, 2007
F
fordtech28
312
Riverside Cali.
Nov 20, 2007
  • Nov 20, 2007
My cobra has been buckling under load the past two weeks and I've tried to solved this problem the past week and I found two things.One two of my spark plug wires were glowing and arcing these are ford racing wires and they are only 7 months old which I'm mad about .Second my coil for some reason is flashing from the sides of the coil between the metal square around the coil when I accelerate the car and I can see flash marks on the coil but the weired thing is that I have two other coils and they do the same thing and I dont think they are supposed to do that one of the those coil is the original one which was good I just upgraded to a MSD one and the other is a friends that we removed from his car to upgrade it but was working fine.So I'm at a lost why these coils are flashing from the sides any ideas?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 20, 2007
  • Nov 20, 2007
The flashing from the coil is the electricity from the coil jumping to the nearest ground. Electricity takes the path of least resistance, so it's now harder for the electricity to get to the spark plugs than it is to jump through the air and ground out through the engine block. When was the last time you checked the cap & rotor on the distributor? If the contacts are corroded, that could be your problem.
The coil wire could be the problem as well. See if your buddy will let you borrow his coil wire as a test, and see if the coil is still arching to the bracket. If you want to go this far, borrow his cap, rotor and spark plug wires too.
I don't think this is the issue, but you may want to check the engine block ground. You should have a wire reaching from the driver's motor mount bolt on the block, over to the frame on that side. I'd make sure the connections are tight and aren't corroded.
Do you have any other electrical issues with the Cobra? Any gauge issues, battery dying, etc?
HISSIN50
34
129
Nov 20, 2007
  • Nov 20, 2007
What plug gaps do you run?
F
fordtech28
312
Riverside Cali.
Nov 20, 2007
  • Nov 20, 2007
The cap and rotor were replaced at the same time as the wires which is leading me to believe I have a bad set of wires since chytar is right about the wire resistance I run .50 gap and been running it like that since I got the car with no issues
F
fordtech28
312
Riverside Cali.
Nov 21, 2007
  • Nov 21, 2007
I put a extra thick ground cable a couple of months ago just because the old one looked bad everything else on the car works 100 percent except for this problem I changed the wires same result I'm going to double check the gap and change out the cap and rotor since I notice all the contacts were almost black and its has copper tops and the coil contact moves around so hopefully thats it
F
fordtech28
312
Riverside Cali.
Nov 26, 2007
  • Nov 26, 2007
UPDATE 11/26/07
The problem turned out to be the autolite spark plugs.This is the second set that has given me problems and they are under 6,000 miles used .I replaced them with motorcrafts which have last me more than 10,000 miles and the car was instantly better and my gas mileage got way better I was getting around 13-14 mpg since I put them on I averaged 16-19 mpg with the motorcrafts.I will never put autolite spark plugs in my car again
revedup
63
S.F. Cal,
Apr 22, 2008
  • Apr 22, 2008
sPARK PLUGS
ASF 42C's Motorcrafts
i was wondering how long are these supposed tp last?
How many miles you guys been getting.
I heard 25,000 miles is bout right.
got 17,000 miles on them now .
no issues.
what can you guys say bout this
HISSIN50
34
129
Apr 22, 2008
  • Apr 22, 2008
no issues.
As long as they don't break or suffer too much gap erosion, they can last quite awhile. I've run coppers for 50K miles before and I've seen them go over 100K before the gap erosion became so great that a miss developed.
I like to change or atleast inspect them every 30K or so.
revedup
63
S.F. Cal,
Apr 23, 2008
  • Apr 23, 2008
Maintenance from Haynes
This manual calls for 12,000 mile change for plugs and fuel filter!!
Wat can u guys say bout that???
HISSIN50
34
129
Apr 23, 2008
#10
  • Apr 23, 2008
  • #10
What manual are you reading?
The O.G.
145
witch city,mass
Apr 23, 2008
#11
  • Apr 23, 2008
  • #11
what autolites were u using
Zero_chance
1,244
Maricopa, AZ
Apr 25, 2008
#12
  • Apr 25, 2008
  • #12
I had autolite 25s in my 88 for two years before I did a head gasket and intake seal job. Replaced them just because I had the heads off but the ones I took out looked fine. The new 25s lasted another two years till I sold it and who knows how much longer.
BlackVert
5,589
9
98
Bethesda, MD
Apr 25, 2008
#13
  • Apr 25, 2008
  • #13
do you have one of those cold air intakes with a 90 degree bend in front of the maf?
94' Five.0
206
Raleigh, NC
Apr 25, 2008
#14
  • Apr 25, 2008
  • #14
Ok this sparked my curiosity. Are you saying this could cause these kind of symptoms?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Apr 25, 2008
#15
  • Apr 25, 2008
  • #15
Absolutely. The sampling tube in the MAF presumes the air is flowing evenly through, so it can reliably do the math and know exactly how much air is flowing. The 90 degree bend cause the air to flow unevenly through the MAF, so there is either more or less air flowing in the engine than the computer thinks there is. That'll cause the engine to run rich or lean, depending on how the readings are off.
You can sometimes rotate the MAF in the tube to improve the calculations. If the MAF happens to be in the right spot to get a proper air sample, the car will run right again.
hollywoodstang
1,095
Apr 26, 2008
#16
  • Apr 26, 2008
  • #16
Is there special mustang school??? how you guys know all this. 90* pipe will cause air to flow unevenly? even the bend is smooth?
HISSIN50
34
129
Apr 26, 2008
#17
  • Apr 26, 2008
  • #17
It's simple fluid dynamics.
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
03 automatic V6 mustang
  • jewbrew
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
jewbrew
J
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
