Budget 7500 RPM 302
TnPaulMan
49
Can anyone tell me what I would have to do to make a stock 302 turn 7500 RPMs and quit making power at 7000 RPM? This will be my goal and I want to prove to my friends that it can be done and for relatively cheap. I was looking at Thumper's Heads and if those are useful, I would love to use them. Also, I don't think a foreged crank is necessary. I imagine it would be mainly in the valve train that needs to be addressed as well as fuel management and spark. The car would likely see autox or other road racing events so a wide useful powerband is what is desired.
Paul
I buzz mine to 7000rpms with a stock block, crank, rods and KB pistons. Its been together for 4 years now and still going. Over 500 passes on the engine so far. It runs low 11's N/A.
Here is my take on it. You would first need to remove your factory rev limiter via a chip, or tuning software in your computer. You will also need to make sure you have enough piston to valve clearance, and you will need to have strong/good enough valve springs to handle that kind of revving. Not to mention an SFI approved balancer is a good idea to keep the harmonics down, especially since stock balancers tend to break when revving past 6000 rpms, at least for multiple times.
But, what is the point of revving this high if your motor isn't making any power past 5800 rpm or so anyway? Im not sure what you have, but a stock motor just doesn't make much power past 5800 rpm or so. You'd need forced induction, or a high breathing motor to take advantage of 7000+ rpm. There was a guy with a stroked 5.0 with higher compression revving his motor around that rpm...ran very good numbers actually.
His car should be on the anderson ford motorsport website under customer cars.
good luck
Dan
good luck
Dan
That is exactly what I am looking for. I want to use as much stock as I can, but I know that it wont breathe past 6K stock so I know airflow is an issue. That is why I mentioned ported heads and the like. I want a high breathing NA motor and I remember seeing Anderson's 302 pulling past 8K no problem. I just want a high winding motor like the old 289s in the GT40 if you know what I mean. Remember this is a track motor, not a strip motor. I think that NA is the most linear of power bands compared to boosted applications. I currently dont have a motor but I am building a data base for all of this info so when I start, I will be in good shape.
Thanks,
Paul
It wont be cheap.... really no way around it.
-Your going to need top spend some money on a lightweight piston. Wouldnt trust a heavy trw slug.
-I dont know if thumpers head will rev it as high as you ask.
-Seeing as you want it for autoX, id imagine youd destroy the block in no time flat... Going the 1/4 mile would be one issue, but this is probably asking too much. 2 things that kill the stock block are RPM's and harmonics. 50oz balance and 7500 rpm in the stock block going through a road race course may not be the wisest of choices.
-valvetrain, you know what the stuff costs and it all adds up very quickyly.
What do you consider 'relatively cheap'?
I am thinking that if I got good deals on a used block, heads, everything really and shopped around, I think I could spend about 5-7K for a motor like this. Is that too cheap? How hard is it to find Boss 302 blocks? It seems all the Anderson Motorsports guys are running some variant of that block.
Ok, you want high revs and for cheap then heres one way. First, switch to carb because it costs less and run at least a 750 due to the rpms. Use a Vic Jr. intake, any stout cam and since we are roller your half way there. As for heads, do a Clevor conversion using Cleveland 4V heads with lightweight or beehive valve springs. Honestly, I wouldnt use a stock bottom end due to oiling issues, weight and proper balancing techniques from the factory. A good clutch and SFI balancer are a most and you can get an SFI balancer for $100. Thats your cheapest bet, and no way will Thumper's heads flow that much rpm. You need a good size valve and at least 185 cfm intake runners. Since you need a big valve, you'll need to ditch those stock pistons or notch em. Good time to go with something light and if your going NA then it doesnt need to be forged and expensive.
Sweet. So AFR 185s would work well, with the behives, stay roller cam (what make should I get? Isky?), new crank?, new rods?, light weight aluminum slugs, SFI balancer (50 or 28 oz)?
I would rather keep it EFI and I know that will cost a bit more but I see that folks are using Edlebrock Performer 5.0 RPM II says it is good for 7,000 RPM and a 70mm or better TB would be required. I am looking for about 350 at the wheels through a 5 spd. Perhaps the Victor Jr. heads would be my best bet too. Would the springs need to be up graded then? I think the head and intake combo is easy to figure out, it is just the bottom end that I am really concerned about.
Paul
For a stock 5.0, the words budget and high-revving don't go together.
First It can be done. Second, if done correctly it's a mean engine that'll seriously lay down the rubber and would be a real screamer down the track.. However though, thirdly - read the first line in this post :flag:
Well, I know it wont be that stock. But I figure I can spend about 4K and do the work my self and get that kind of motor.
Paul - I think the best money you can spend is to invest a few bucks with Buddy Rawls and have him model some different cam/heads/intakes/exh. set ups. You'll need to be sure that the combo you select will handle the flow at those revs, and that the peak is where you want it to be. And it's gonna take a lot of head/cam to peak at 7000. As for "budget", well, it's only expensive if you can't afford it. :) Can't wait to hear it. Oh, for the revs/power you're talking about, I think static compression ratio is gonna need to be a good bit higher than stock.
Talking aluminum then I think your best bet is either the Vic Jr heads or the highports. They both sport the flow you need and they are both under $1400. Thats a good deal considering youll pay around $1700 for AFR 205s which are in the same class. Go with the Vic stuff since they have matched combos already figured out by the edelbrock engineers. Edelbrock claims the Vic Jr. package peaks at a little over 7000 rpms with a 302. You'll need new pistons for those valves and to lighten them up so best to rebuild everything. Mine as well go with a long rod 302 since they can really rev and you need new pistons anyways. And like Yount says, you'll need more compression. Edelbrock's combo made their power with 12.8to1 comp.
Thanks Mike and Smock-
There is some seriously valuable info comming out of you guys. I know I would have to at least be at 11:1 to make that kind of power. Really I just want useable power at 7K, not really peak. So I think the Victor stuff would work really well. Can some one explain why the longer rod would be beneficial? I read something just the other night from the Isky man himself that said that stock rod length is the best combo and to not change it because it only increaces wear. Here is the link: http://www.iskycams.com/techinfo_index.html
I think it is good info. What would you say would be a good cam to go with that Victor Jr combo? What do you guys think about a single profile cams? Again, Isky says for a circle track car or even all out drag, single is the best. What about road race?
Intake/exhaust duration Paul only make sense when viewed in the context of the flow capabilities of the heads/intake/exhaust. Dual pattern cams work well (more exhaust duration) when you've got a flow deficiency, usually in the head, on the exhaust side. The Ford Racing X and Y heads are this way - their flow is intake biased, and they need help in the form of more duration and/or lift from the cam on the exhaust side to make up for the lack of exhaust flow in the head. So you see, you really need to pick heads/intake/exhaust system that are capable of enough flow to support your HP requirements, and then select valve timing events and CR such that the power peak occurs where you want it to. I firmly believe that without a professional modeling it for you, any cam choice is gonna be purely a guess. Valve timing events are what need to be selected - not lifts and durations.
Here's a link regarding rod length/stroke ratios and the implications. It's aimed at strokers, but the principles are the same. Going with a longer rod will give you a higher rod length/stroke ratio. As you'll see, the pros of a long rod engine are in your favor if you're building a high revving small block. But it's probably not a huge advantage. For the money it would cost, you'd be much better off getting Buddy or Ed to model things for you to help you select heads and cam. I'm a broken record. Here's an excerpt:
Pro:
» Provides longer piston dwell time at & near TDC, which maintains a longer state of compression by keeping the chamber volume small. This has obvious benefits: better combustion, higher cylinder pressure after the first few degrees of rotation past TDC, and higher temperatures within the combustion chamber. This type of rod will produce very good mid to upper RPM torque.
» The longer rod will reduce friction within the engine, due to the reduced angle which will place less stress at the thrust surface of the piston during combustion. These rods work well with numerically high gear ratios and lighter vehicles.
» For the same total deck height, a longer rod will use a shorter (and therefore lighter) piston, and generally have a safer maximum RPM.
Con:
» They do not promote good cylinder filling (volumetric efficiency) at low to moderate engine speeds due to reduced air flow velocity. After the first few degrees beyond TDC piston speed will increase in proportion to crank rotation, but will be biased by the connecting rod length. The piston will descend at a reduced rate and gain its maximum speed at a later point in the crankshaft’s rotation.
» Longer rods have greater interference with the cylinder bottom & water jacket area, pan rails, pan, and camshaft - some combinations of stroke length & rod choice are not practical.
To take advantage of the energy that occurs within the movement of a column of air, it is important to select manifold and port dimensions that will promote high velocity within both the intake and exhaust passages. Long runners and reduced inside diameter air passages work well with long rods.
http://www.victorylibrary.com/mopar/rod-tech-c.htm
Mike, you are the man. I need to run out to Knoxville and see you run that car of yours and buy you a beer.
Thanks for the great info. I will not ask anything else until I actually do it because it would be totally useless at this point. But I am saving every bit of info.
Paul
No problemo - it's past time for a get together; I always enjoy your company. Headed over to Charlotte to visit a good friend who's coming down from DC to watch/help his 12 year old son go kart race in the infield track at the speedway. Should be back sometime Sat.
Things must have changed, 4 grand isn't exactly a budget finance to me :cheers:
You should be able to reach your goal barely with that type of finance. As Mr. Yount said, buy parts that would meat your engine's goal(s). The biggest key is to get everything to work together in the most efficient means possible. Lighten the rotational mass on the internals, get some deep-breathing cylinder heads, and high-volume intake manifold and/or carb, and slap a cam in there that ties it all together yet at the same time will meet the demands that all other parts of your engine place upon it. The cam is the heart and sole of an engine and the timing is the beat/rythm - get them in sync as well by means of the best possible choices you can make for your combination, and you've got your goal :nice:
