I'm condemplating building up my stock bottom end and maybe even my heads.I'd like to see what you guys think. I'm going to try to squeez out 600hp, how or what should i do to achieve this. I am already at the limit with my stock bottom end due to the high compression I'm running.
I know I'm gonna need a new (better) supercharger with an intercooler what do you recomend centrifical or twinscrew? I was thinking twinscrew due to the blower and the intake manifold being 1 peice.
I'd like to stay w/the 4.6 just in case I can use anything that I already have but I know I will need a well built bottom end.
(before you read my mods the car is safly tuned) My car currently has 11 lb powerdyne w/no intercooler, PI intake, PI heads not ported but have beehive springs w/comp cams 270's, BBK 75mm throttle body,C&L plenum, Diabo tunner and MAFIA. (NOT SURE IF I'LL BE ABLE TO USE ANY OF THIS FOR THE UPGRADE).
I'm gonna need a built AODE tranny any suggestions?
let me know what you got for info.
Or do I just buy another car? (don't realy want to).
It will be a huge help to get the power numbers you are looking for, and E85 will give you a much nicer mid range than would ever be possible on a gasoline combination. To tell you how much fun E85 is, imagine 22psi on 10:1 compression with an aggressive amount of timing advance. That's what I'm running on my 2.3.
