Building a 1971 351W -2v need more help..going to machine shop
those heads are procomp brand which are made in CHINA, they are loose copies of edelbrock vic jr heads, its hit and miss with those heads, yes they will blow the doors off your stock heads in performance BUT, there can be problems with casting shift,uneven surfaces, valve guides etc.... I have know guys who had them work perfectly and others who had majore engine damage occur because of them. Best bet if you want those heads, buy them bare take them to a competent machine shop and have them assembled with quality parts OR find some used edelbrock, trick flow, AFR or even ford gt 40x or similar aluminum heads, for about a grand you can buy brand new twisted wedge or edelbrock performers or e street heads, with any of them you will have to buy new rockers and pushrods, for a cheap alternative the old cast iron gt-40 or windsor/jr heads can be found for a good deal, if you go with the aluminum heads you can run your flat top pistons and have many more cam choices and get that "lope" and the performance that goes with it you can run up to 11.1 compression with the right cam on pump gas with alum heads no problem.
your cheapest alternative is run gt-40, gt-40p (requires special headers), windsor cast iron heads, the 268h cam and 9.1 compression (Dished) stock rockers and even if you dip to 8.8 compression you can degree the cam or run more timing to make up for it.
I'll tell you, I had a 69 351w, 351w ported 69 heads (heavy bowl work) with guideplates, screw in studs and chevy 1.94 and 1.60 valves. 9.1 compression, 268h cam, 1 5/8 headers, 2 1/4 exhaust, performer intake that I port matched and a 1" spacer, a 670cfm old analog holley projection 2 TBI.
This was in my 67 vert with a c-4, 289 converter and 3.00 gears, I ran mid/high 13's in the 1/4 mile, 0-60 in 5 secs and 19 mpgs hwy. The combo had so much low end it would fry the tires, not much pull past 5000-5500 but it got there real quick and in closed loop it would have a mild lope as well as is did with a carb, I have a 500hp 408 in the car now with a lentech AOD but back then I could hit almost 80mph in first gear, peg the speedo in second and have a bit more in third. The comp cams 268h was and still is a great cam with the right combo, with better heads and compression you can do much better. But that combo worked great back then, I used to race my buddy in his 64 chevy 2 with a 383 stroker, cam and TPI and 3:73 rear gears and I would always beat him by 1/2 a car length at 120 mph.
He would always be so pissed because he head more cubes,gears and lighter he always thought I had hidden N20, a good properly matched 351w will always beat a cheby.
Thanks Guys....your help is great....those were the Comp china heads (how did you know that???) .....I think I'm going with D.H....run the 268 - dished pistons...stock heads...do that bump out on the exhaust side....I'm trying to upload pictures on this ..it always falis....upload failure....but with the way things are $$ wise ...as long as it runs good....I can always tear it out again and upgrade to the flat tops/alum heads...that 69 351w that Htwheelz spoke of... sounds exactly like what I had wanted ...the lumpy idle and tear ass low end torque...street light to light I don't care alot above 5500 rpm's ...anyway ...I'd like to post some pic's ...I have a "clean" table with the parts that I've restored...thought everyone would like to see.....plus when I actually start rebuilding this...I think it's easier to "show" what is going on than rather me try and explain it..my christmas list was chuck filled with parts for this motor....and since I'll be doing this re-build w/alot of help from friends ....it's going to be really interesting....went to the goodguys car show here in AZ....it really gets you thinking.....if anyone knows how to upload pictures when on the forum..please let me know...but thanks for all of the help...hope everyone has a safe and fun Holiday....
