Building up 289?
  • Thread starter Thread starter 66nightMARE
  • Start date Start date Jun 12, 2005
66nightMARE
97
Katy, Texas
Jun 12, 2005
  • Jun 12, 2005
What do ya'll think would be the best combo to reach around 350 HP?
Thanks in advance.
rbohm
6,698
550
204
tucson,az
Jun 13, 2005
  • Jun 13, 2005
1: heads, you will need a set of good aftermarket heads like the windsor sr, afr 185's, tfs twisted wedge, or edelbrock performer rpm heads.
2: either a weiand stealth or performer rpm intake with a 600 to 750cfm carb.
3: you will need a fairly serious cam as well, something like the performer rpm at a minimum, but more like an xe282h extreme energy can from comp cams.
4: heads, a set of hooker super comp headers with a 1 5/8 or 1 3/4" primary tube.
5: the rest of the short block needs to be balanced, use a good forged piston cause you are going to turn some rpm(around 6500 with the 289), and replace the stock rod bolts with a set of arp wave lock bolts. also have the rods polished and shot peened for maximum strength.
6: you are going to want to use the hipo 289 balancer at the least, and better would be a good aftermarket sfi rated balancer.
SoCalCruising
2,437
SoCal
Jun 13, 2005
  • Jun 13, 2005
Buy a new Scat 3.0" stroke crank, 5.090" I-beam rods and 302 pistons. Then, add cylinder heads, cam, intake and headers. No problem making 350hp.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Help Me Build a 289
  • 66Stang1
  • Sep 18, 2025
Classic Mustang Specific Tech Sep 18, 2025
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
F
Best plugs for carb'd roller
  • forango
  • Nov 21, 2025
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
HotFox
