Throttle body size = 65 MM or 70 MM, Accufab for best flow. If you use the 70 MM, it is the best choice for track.
My Comments:
A lot of people oversize the fuel pump by buying a 255LPH pump thinking that the fuel pump regulator will just pass the excess gas back to the tank. It does, but… Did you ever consider that circulating the fuel around as a 255 LPH pump does will cause the gas to pickup engine heat? What happens to hot gasoline? It boils off! With most of the 5.0 Mustangs having the carbon canister removed or disabled, the car stinks like gas, and the gas mileage drops since the hot fuel evaporates away into the air.
?********So your recommendation for removing the "Carbon Canister" I understand, would be: <Not to do it>? Why do you think guys are removing it - what is their expected gain????
