BULLITS WITH DRUMS?
  • Thread starter Thread starter cmb91LX
  • Start date Start date May 3, 2004
cmb91LX
432
Memphis
May 3, 2004
  • May 3, 2004
Will 17x9 Bullit wheels work on a fox body car with 5 lug rear drums from the Motorsport 5lug conversion? Will they rub the quads? Will the fenders need to be rolled? There will be 17x8s on front so I dont anticipate any rubbing up front. Any advice would be helpful.
Matt90GT
3,055
Oregon
May 3, 2004
  • May 3, 2004
yes works fine on the rear with drums.
up front, you need the Sn95 parts
cmb91LX
432
Memphis
May 3, 2004
  • May 3, 2004
will they work on the front with the FRPP 5 lug conversion kit? Are these equivalent to the SN95 pieces?
Kurt2002
346
North Royalton, Ohio
May 3, 2004
  • May 3, 2004
yes they work and look fine see link http://ml.truckmoxie.com/gallery/kurt93GT/96823.jpg
http://ml.truckmoxie.com/gallery/kurt93GT/96532.jpg
You will have to remove the quad shock. I'm running 17X9 in the rear and 17X8 front. If you get the 5 lug rotors you can use the Bullitt Wheels. I did the sn95 front spindles.
Matt90GT
3,055
Oregon
May 3, 2004
  • May 3, 2004
Does that kit come with spindles???
If you can answer that, you will answer your own question
cmb91LX
432
Memphis
May 3, 2004
  • May 3, 2004
thanks for the pic, that is what i wanted to see, looks good. About the front spindles SN95, what is the part breakdown list and differences between those and the FRPP kit if any? Do the 17x8 wheels rub with the SN95 kit up front at all?
Kurt2002
346
May 3, 2004
  • May 3, 2004
No 17X8 don't rub on my car. I also have Gatorback up front which are not as wide as some tires.
I went to the junk yard and picked up the front spindles off a 94-95 V6/GT mustang. They included the spindles, calipers and rotors. I ordered new SS brakeline from MM so I scrapped the junk yard ones. That is it, take your old 4 lug off and replace them with the new ones. I paid $100 a side for mine you may get it cheaper.
Check these links out they help a lot
http://www.stangnet.com/tech/lug.html
http://sn95brakes.cjb.net/
JaysGreenLX
2,252
Buffalo, NY
May 3, 2004
  • May 3, 2004
FRPP 5 lug set up uses a one piece rotor/hub design. The SN95 cars use a modular rotor and hub design in which the hub is sealed and does not require regular repacking of the bearings. This makes for a smaller dust cap. The FRPP kit uses the same large dust caps that are on the 4 lug rotors meaning you won't be able to run center caps on your Bullitt wheels.
SCORPION
386
Seaford, DE
May 3, 2004
  • May 3, 2004
those do look good....what about going 17s in the back and 16s in the front...is that ridiculus?
JaysGreenLX
2,252
Buffalo, NY
May 3, 2004
#10
  • May 3, 2004
  • #10
17's all around looks better IMO
Kurt2002
346
May 3, 2004
#11
  • May 3, 2004
  • #11
I think so, but hay you never know unless you try
cmb91LX
432
Memphis
May 4, 2004
#12
  • May 4, 2004
  • #12
Will I need to upgrade to a different master cylinder of will my 91 work with the SN95 kit?
Kurt2002
346
May 4, 2004
#13
  • May 4, 2004
  • #13
the 91 will work but you may have more pedal travel before it brakes.
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
