Bullitt Rims with this conversion kit?
  • Thread starter Thread starter Nopantz
  • Start date Start date Jan 13, 2007
Nopantz
234
NJ/US Merchant Marine Academy
Jan 13, 2007
  • Jan 13, 2007
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-4234K%20%20%20%20%20%201&comp=LRS
Will 17" Bullitts fit on my car with this kit?
bubba-dough
1,044
Indiana
Jan 13, 2007
  • Jan 13, 2007
Not without wheel spacers. Those wheels require the SN95 spindles.
Nopantz
234
Jan 13, 2007
  • Jan 13, 2007
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=WSP-PA1%20%20%20%20%20%20%20%201&comp=LRS
so if i used these bad boys it would work?
FAST4ORD
306
Gibsonia, PA
Jan 13, 2007
  • Jan 13, 2007
A friend of mine ran ford bullit wheels with that style conversion, but he could not run the bullit center caps.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Jan 13, 2007
  • Jan 13, 2007
Possibly. But the wheels may stick out so far they hit the fenders over bumps.
That 5-lug conversion kit is basically the Mark 7 rotor and ranger axles and drum kit.
Do you have the bullitt wheels? Or access to someone with a set? You could go to a parts store, buy a Mark 7 rotor and test fit it out. I beleive the OEM bullitts and aftermarkets fit differently. You may be able to mount the wheel, but the center cap won't fit at all.
Snikt89GT
264
Deland, Florida
Jan 13, 2007
  • Jan 13, 2007
Just do the real conversion, you don't want those crappy rotors and to add a wheel spacer
bubba-dough
1,044
Indiana
Jan 14, 2007
  • Jan 14, 2007
Exactly. I put a pals Bullitts on mine and the center cap would not fit. And it looks like total crap if you don't run the center caps. But then again Bullitts look like crap on a red fox, imo.
Nopantz
234
Jan 14, 2007
  • Jan 14, 2007
can u guys point me in a direction of a kit that works. Ford sells one for over a grand, would that be the one i would need? im considering a bullitt theme with my car which includes painting my car dark highland green and throwing some bullitts on there.
To keep this tech the reason they wont fit is a clearance issue? does it invlove backspacing? I am gonna get aftermarket ones not Ford OEM.
bubba-dough
1,044
Indiana
Jan 14, 2007
  • Jan 14, 2007
http://mjbobbitt.home.comcast.net/mustang/5lug.html
http://www.stangnet.com/tech/lug.html
Its all in what you want to do. To be able to run about any 5 lug wheel and to get better braking do the entire SN95 swap.
bubba-dough
1,044
Indiana
Jan 14, 2007
#10
  • Jan 14, 2007
  • #10
It is a clearance issue but its not with the wheel its with the rotor's "hat" or "center hub" whatever you want to call it. It is too tall.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jan 15, 2007
#11
  • Jan 15, 2007
  • #11
Do the SN95 Conversion, you will be thrilled with the Braking performance and your wheel selection.
tbovee
129
Fredericksburg Va
Jan 15, 2007
#12
  • Jan 15, 2007
  • #12
7upstang posted this info in another thread. They sell complete brake setups.
http://www.mpsautosalvage.com/products/list.cfm?TypeID=39
Nopantz
234
Jan 15, 2007
#13
  • Jan 15, 2007
  • #13
thanks man...that looks pretty inexpensive also...hello bullitts
Nopantz
234
Jan 15, 2007
#14
  • Jan 15, 2007
  • #14
If I were to run a SN95 Brake Setup is there anyway I could run a 17x10.5 inch rim out back?
P
PRO50SC
1,012
Olney, Maryland
Jan 15, 2007
#15
  • Jan 15, 2007
  • #15
OK here's the deal. I ran those for 3 years w/o any problems. 3/8" spacers on the front, the wheel did not stick out, shoulder style lug nuts that reach into the wheel for more stud thread retention, modified the dust and center caps. You could not tell any difference. Worked fine.
Nopantz
234
Jan 15, 2007
#16
  • Jan 15, 2007
  • #16
Im assuming your talking about my original post...thanks for the feedback
P
PRO50SC
1,012
Olney, Maryland
Jan 15, 2007
#17
  • Jan 15, 2007
  • #17
That's correct and you're welcome
QUICK91LX
968
New Jersey
Jan 15, 2007
#18
  • Jan 15, 2007
  • #18
maybe, if you used the SN95 axles and brakes. my 17x9's have a much wider track than stock and there is plenty of clearance. you will still have to ditch your quadshocks though. its gonna be tight either way.
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
Brakes Need help ID’ing which brake lines and seals I need
  • AnthonyA1234
  • Apr 2, 2025
Fox 5.0 Mustang Tech Apr 14, 2025
limp
  • dan50
  • Jul 18, 2026
dan50
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
