C codyGT New Member Apr 11, 2004 365 0 0 Nebraska Dec 17, 2004 #1 Dec 17, 2004 #1 Are the Bullitt 28mm front sway bars hollow or solid? What is stronger a 29mm hollow or a 26mm/28mm solid?
8 8yourZ06 New Member Feb 16, 2004 128 0 0 Dec 18, 2004 #2 Dec 18, 2004 #2 codyGT said: Are the Bullitt 28mm front sway bars hollow or solid? What is stronger a 29mm hollow or a 26mm/28mm solid? Click to expand... I believe they are tubular. I would guess and say a solid bar would be stronger than tubular one but another aspect to it is that your reducing unsprung weight when use use a tubular bar. The less unsprung weight you have the better.
