  • 1994 - 1995 Specific Tech
bumpsteer
  • Thread starter Thread starter mustanglvr95
  • Start date Start date Mar 17, 2008
mustanglvr95
32
marysville, WA
Mar 17, 2008
  • Mar 17, 2008
ive been reading up n asking around cant seem to decide...ive heard that the bump steer kit helps and doesnt ?? my car over bumps and uneven roads pull to right or left hard sometimes, figured its just my low car with wide tires in front..can someone chime in here, will they fix that prob??
P
PJC Racing
199
  • Mar 17, 2008
Are your tie-rod ends parallel with the rack? If not a bumpsteer kit should help.
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 17, 2008
  • Mar 17, 2008
Here's what I suggest to solve your problem:
1. Check the tie rod ends for excessive play. If they're worn, they'll need to be replaced.
2. The pulling to one side is probably due to worn steering rack bushings. I suggest you replace them with urethane units; standard bushings if the car is lowered up to 1-1/4", offset bushings if it's lowered more than 1-1/4".
3. Have the wheel alignment checked. Bumpsteer is increased if there's too much toe out.
mustanglvr95
32
marysville, WA
Mar 17, 2008
  • Mar 17, 2008
well its slammed..prob like 2-2.5 inches..did get an alignment not too long ago..recently ordered mm cc plates, thought put that n bumpsteer in get it aligned prob help quite a bit
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
  • Locked
SOLD Maximum Motorsports MMTR-2 Bumpsteer Kit - 1979 - 1993 Mustang
  • AeroCoupe
  • Apr 18, 2025
Fox Body Mustangs For Sale (1979-93) Aug 5, 2026
AeroCoupe
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
