Burned a lot of OIL
Morales
136
Miami, FL
I recently went with a K&N Oil Filter last oil change. After the oil changed I started the car and let it run for leaks. As I peered down beneath the car i noticed a long line of oil dripping from the K&N. I uninstalled and reinstalled and it continued to do it. I encountred this problem with K&N Filters once before a few years back when I had an 87 Trans Am. I monitored it for a few minutes and it seemed to stop.
Today I checked and my car was pretty low on oil. There doesnt appear to be any oil where i park at home.. im guessing that it's dripping out when I drive the car. Im not going for K&N anymore and Im just going to stick with the Motorcraft Filter.
Here's the real issue in Decmber, im upgrading the H/C/I with the Trickflow setup. Im guessing it's the K&N Filter that caused the leak because of what I observed. If however that wasn it and I do have an engine leak when I replace the H/C/I what should I look for? Im hopping once i upgrade and put in the new seals and what not that, that if it is the problem will solve it.
thanks
Um yeah, if you are leaking at the filter only, make sure the old gasket came off, the surface is clean, that your old filter-seal did not tear, etc.
Good luck.
