This 220,000 mile 1989 mustang 5.0 5speed is running strong.
It did burn 1 quart oil in a 150 mile run in hot weather.
It doesnt relly leak.
Ive been driving this car over 10 years .
Its never been apart the engine!
Im at a crossroads.
Iwonder if it's valve seals?
I imagine to change them might be a job and i only got 1 car.
Danger to change them would be dropping the valves in the cylinders right?
I guess you have to rotate engine to make sure each piston is at top dead center to do each valve seal.
I know i should compression test wet and dry, aint done it in awhile.
Guess i'd need a valve spring compressor too?
car runs strong and idles smooth,its why i doubt the compression is lowor uneven.
I wonder if my rings are are allowing oil into combustion chamber?
Time to smog in 2 months!
Im thinking just maybe valve seals need changing!
Any engine pros, stangsters, 5.0 guys and gals want to recommend comment, ect any and all ideas will be apreciated
Thanx to all who at least read this
This 5.0 engine has been amazing, and im concerned about it's future!
Help save a 5.0!!!
Im at a crossroads.
Help save a 5.0!!!
