  • 1994 - 1995 Specific Tech
Burning Oil......
  • Thread starter Thread starter stallion09
  • Start date Start date Dec 16, 2004
stallion09
  • Dec 16, 2004
95GT original owner normally change my oil every 3000 miles (Synthetic).
Yesterday I notice the check oil light and I discovered I am about a
quart low. My last oil change was 9/21/04. In that time I drove less than
3000 miles. Do I have a problem on my hand?
Joes95GT
3,132
Delaware
Dec 16, 2004
  • Dec 16, 2004
I think Ford says that 1 quart every 900 miles is "acceptable." That, in my opinion, is not acceptable. Anything more than 1 quart per 3000 miles is not acceptable.
You do have a problem, albeit (probably) a very slight one. Does the car smoke at all?
Joe
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 16, 2004
  • Dec 16, 2004
You might just have a small leak some where. Check the rear main seal, oil pan gasket, even around the harmonic balancer. Does it blow out blue smoke out the tail pipes at all?
Joes95GT
3,132
Delaware
Dec 16, 2004
  • Dec 16, 2004
AKA - Front Main Seal.
Joe
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 16, 2004
  • Dec 16, 2004
Smart @zz . Actaully I was referring to the bolt mine leaked oil from there I had to take the bolt out and put RTV on the treads and that fixed it. Yeah thats it
DFG 5OH
1,341
Louisville, KY
Dec 16, 2004
  • Dec 16, 2004
mine burns about a quart every time i change the oil, most mechanics i talk to say that they'd rather have a car that burns oil.
stallion09
  • Dec 16, 2004
Sounds like maybe I should not be so worried. Thing is it is the first time
I have had this happen. There is no blue smoke nor does the car smell. I will
check to see if I can find a leak.
DFG 5OH
1,341
Louisville, KY
Dec 16, 2004
  • Dec 16, 2004
dont worry about it man, i was worried when i first found out mine burned oil, but just keep an eye on it, and fill it up when it needs it. No Prob
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 16, 2004
  • Dec 16, 2004
That is a good sign that your car isn't smoking. Sounds like a leak to me.
These kinds of leaks can be hard to find. If the leak isn't obvious, then you might want to add some flourescent dye into the oil and try to find the leak that way. But typically oil leaks are easy to spot.
Scott
HISSIN50
34
129
Dec 16, 2004
#10
  • Dec 16, 2004
  • #10
also, synthetics tend to burn a bit more than dino oils. the EFI 5.0's have low tension rings which does not help much.
i too would not sweat it too much.
good luck.
Joes95GT
3,132
Delaware
Dec 17, 2004
#11
  • Dec 17, 2004
  • #11
LOL.
For humors sake, you should ask them why. I'd be interested in knowing...
Joe
Soupy
76
Rhode Island
Dec 17, 2004
#12
  • Dec 17, 2004
  • #12
While looking for this potential leak, check on the lower manifold against the firewall. There is a PCV valve and screen there. I've seen these things pop out and vent oil down the back of the motor and onto the trans.
91LX_5L
1,943
British Columbia
Dec 17, 2004
#13
  • Dec 17, 2004
  • #13
yeah burning oil is not good, not saying its that bad iv had a car that burned hella oil but still ran great.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
