Make sure that if you do buy poloyurethane bushings to not use poly in the diff houseing. Put them in the lower control arms and only one in the uppers. Be careful when you put them in too. Your car will react differently. I drove my car on the track after I did mine and with rubber bushings, you can tell when the rear is going to kick out, with poly, you get grip and grip and then your rear will come around and scare the piss out of you. I just installed a panhard bar and no more rear end crazinness.....unless you really get on it.
