Bushings
Beasty306GT
671
Oxford,Mass
So recently i got my rearend rebuilt and had some 3.73 gears installed.... Also had the upper axle buchings installed.......Problem is the guy pressed the bushings in to far. I know there is a tool for them but does anyone know of any way to push the busings out an 1/2" ....really dont want to waste money on a tool im gonna use 1 time....thanxs any suggestions im open to
In my experience, there's no tool to push it out.
I've only seen it removed one way, and it's the same way I do it... you must air chisel/punch it out.
I imagine if you're trying to save it and only move it very little, you could use a bolt, nut w/washer and try drifting it a bit? Chances are you'll just flare the outer housing piece though.
