Today was the big day, the day I found out that I didn't really know how to put a new convertible top on a car.
Ah, it's not really that bad. The top is just a little off. It looks like it's all in the right place except for the window sagging a bit and the wrinkles in the top quarter panel sails, or whatever they are called.
I also found out my instructions were lame, lame, lame. Well, they at least got me going in the right directions. There were even pictures. They were just vague. It didn't help that the new top has more material (is larger all around) than the old one which you are supposed to use as a template.
Anyway, I wish you guys could help me, but I know most sane people run and hide anytime someone says anything about a convertible top install. Now I know that is for good reason.
So, I'm going to pull the staples out of the rear window and slide it down a bit to see if I can get the window tighter. I could live with how it is now, but I really don't want to.
The same for the quarter sail panel thingys. What's weird is that the seams at the quarter windows and the flaps that glue to the frame are in the right spots. But, the whole top from the final header bow (the thing that all the top pieces get attached to) seems a bit to far forward.
I could wind up making it worse.
Um maybe I'll just do the window.
I think I know why the top seems not to be in the right spot. It's because the main header bow is supposed to be farther forward on this new top. There is nothing I can do about that because the two tough canvas quarter sail pads I reused force the bow to be where it is. Oh, hum, so If I move the main top back a little that might pull things back into place.
That just means I have to undo all the staples in the tack strips. Worse I have to remove the bolts that were nearly impossible to line up from the tack strips to take them out of the car.
Woo is me.
Woo is me.
