OK, ive priced out about everything needed for the swap. minus gaskets.. etc etc, which would be needed either way. and not sure if my march brackets will work with the 351 or not. so not pricing those yet either
anyways, heres what ive written up so far.
BBK shorty 351w swap headers, polished ceramic $319.88
BBK 2.5" H-pipe without converters $159.88
MSD Pro-billet distributor, EFI w/ steel gear $281.88
Trickflow lower intake manifold only, EFI, 351w $307.95
FMS aluminum crankshaft pulley spacer $28.88
Ford racing 351w swap, oil pan & pickup kit, 5.5 quart $131.88
Thats a grand total of
$1,230.35!
Now, its a given with more power id probably need to replace other stuff either way.
190lph fuel pump probably need a 255..
24lb injectors.. probably should go bigger
mass air meters a given if you touch the injectors
i read the timing cover should fit. so im assuming my electric water pump will fit also.
Anyways...
is an added 61 cubic inches, and the added strength of a 351 over a 302, worth the added $1,200?
thats quite pricey. but nothing about these cars is cheap.
now its on to trying to contact rick, and see what the difference in a 347 to a 408 runs price wise.
What would you guys do?
