Ok SVOconv, this is how it works here on stangnet.
Every week atleast 10 people just like yourself post the SAME question, oddly in the same fashion. Each time the Senior members here tell them to do a search.
This happens for a few reasons. If you learn to search
A: you will get your answer faster
B:You save a post
C:you may learn other problems or tips that go along with that search item.
No one is being hard on you, but at the same time you cant Spell until you know your ABC's. We all started there at one point or another, not better, just been here longer is all.
Boost controller-
A device that controlls the amount of Boost the Accuator is exsposed too
Accuator-
A spring loaded diaphram that opens or closes the waste-gate depending on the boost pressure it sees.Most springs are set to open at ~10psi.
Waste-gate-
A little door in the back of the turbo that opens to alow exhuast to bypass the turbine.
Blow-off valve-
A vavle that release positive intake manifold pressure when the throttlebody closes and the motor returns to vaccum.
Bypass-valve-
Much like a blow off vavle, a bypass releases positive manifold pressure, but the released pressure is piped back infront of the turbo...Meaning no "metered" air is lost, just recirculated.
