  • Mustang Sound & Shine All
Bypassing Mach460
  • Thread starter Thread starter JMack
  • Start date Start date Dec 15, 2006
J
JMack
9
  • Dec 15, 2006
alright I made this crude drawing in MS paint to explain what i'm trying to say. what I'm suggesting is taking the plugs out of the amps (these plugs hold both the input from the head unit wires and the output to the speaker wires) and basically makeing jumpers (as shown in picture) to bypass the amps altogether
I would be putting in a new headunit at this time and my stock amps no longer work correctly. Would this setup work, or would the change in resistance (ohmage) screw up the speakers.
Thanks for any input, sorry the drawings are crappy
image is attached
ChingonStang
308
Dallas, Tejas
Dec 15, 2006
  • Dec 15, 2006
I would just run new wires since you are putting in new amps and a new headunit. Besides, the way the speakers are wired up is wierd per via the Mach 460 amps. I hope you are changing the speakers out also as they will most likely not be rated to your amps. My old 96 had Mach 460 that was removed and I ran new wires as to not give myself a headache trying to figure out the spagetti that is the Mach 460 wiring schematic.
And you don't want one amp powering the left and the other the right side speakers. You want one amp powering the fronts and the other the rears.
J
JMack
9
  • Dec 16, 2006
I would not be putting in new amps, just a head unit. I will probably get an 4000 watt amp for my subwoofers that im gonna put in after I put in the headunit.
ChingonStang
308
Dallas, Tejas
Dec 16, 2006
  • Dec 16, 2006
Oh, you will need to do more research as the tweets in the Mach 460 don't have bass blockers and like I said before, the wiring of the speakers is wierd from the 460 amps.
And 4000 watts for subwoofers over possibly 50watts per channel for speakers via the head unit? Yeah...that's gonna sound really nice and boomy.
T
turbogt
723
Montana
Dec 17, 2006
  • Dec 17, 2006
The speakers are what carry the resistance. so there would be no change in resistance, and it would most definately not hurt the speakers.. Problem is, the frequencies are divided up like in a crossover inside the factory amps, so you will not be able to send only highs to the tweets, etc.
J
JMack
9
  • Dec 18, 2006
Would you recommend a harness to connect to the new headunit from the factory wiring? Would you know where I could get one?
J
Mach 460 System Replacement
  • Jabertooth
  • Jan 24, 2023
3K
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2023
COramprat
Cooling Fan Not Working
  • brian m1
  • Jun 21, 2024
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 26, 2024
horse sence
K
Electrical charging issue
  • knucklehead11
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 16, 2024
Mcmahst
1993 Premium Radio replaced, want to replace and bypass factory amp
  • JimProfit
  • Jun 25, 2022
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2022
JimProfit
Electrical 3G alternator over charging
  • sav22rem22
  • Jun 15, 2023
2K
Fox 5.0 Mustang Tech Jun 17, 2023
sav22rem22
