Bypassing Smog pump
  • Thread starter Thread starter CRASH7772
  • Start date Start date May 7, 2004
CRASH7772
401
NH
May 7, 2004
  • May 7, 2004
If I just bypass the smog pump with a shorter belt and not doing anything else will it cause any problems other than possibly locking up the pump from not using it over a peroid of time? Will it pop any codes in the computer?
Kdubslugga
1,515
Akron, OH
May 7, 2004
  • May 7, 2004
It wont cause any problems with your computer, it could hurt your cats if you have em, and it will lock up if not used for awhile, thats what mine did, but its gone now anyways. Just occasianlly turn the pump so it wont lock up though
CRASH7772
401
NH
May 7, 2004
  • May 7, 2004
Check sig.....installing Pro-Chamber soon...
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 8, 2004
  • May 8, 2004
It will store codes but not throw a light. No other problems.
The Shape
2,224
East ARKANSAS Delta
May 8, 2004
  • May 8, 2004
A friend of mines car stores codes for the smog stuff being gone , but no check engine light just as 89MustangGX said. Mine doesn't even store a code though. I am wondering if that is because I left the solenoids on the back of the strut tower and just capped them off instead of removing them . The only thing I get is code 11 all clear.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 8, 2004
  • May 8, 2004
Why just bypass it, why not delete it. I did my emmisions test with and without the air pump, made no difference. The air pump / smog pump is just an example of 1980's emmisions technology. The air pump has nothing to do with your EGR, now that you want to keep if you have to pass emmisions. The air pump pushes air into the cats and into the exaust ports in the head. Who cares how it works, it's junk.
The way I deleted it is two bolts the pump comes out, remove the vaccume lines and plug them, then two 1/2" bolts on the back of the head removed, cut off the pipes and bolt the flanges on backwards to block the back of the head.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox Help my smog pump :poo: the bed.
  • nickyb
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2025
nickyb
Smog pump bypass?
  • PvolkStang
  • Apr 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
nickyb
