Fox Help my smog pump :poo: the bed.
Master pro K060841 from O'Reilly's fits .
Its 84 9/16 inch. The pump is from cardone.
Now I only paid $49.99 back in 2008 for it, got one under warranty in October of 2020 that was $249.99.
Its last price was $300+
But no longer available, so I'm gonna keep it and one day try and rebuild it.
There are rebuilding services available for smog pumps.... probably gonna be pricey. It's an option if you have to have one though.
Edit - here's a random one a quick search turned up. I'm sure there are others.
You really only need the air pump if you are running original cats. With modern aftermarket h-pipes, the air pump isn't necessary. If running an off-road pipe, don't need it at all.
What failed on the smog pump? The bearings are readily accessable and not hard to split it apart and swap those out
Yeah I got BBK catted xpipe, but would like to keep the pump and it sounds like bearings are worn.
Where would I buy the bearings ?
Thanks ,that'll be my winter project.
I do think ill get one in the pic a part yard , if I can find one and practice on that.
