C-Back problem
  • Thread starter Thread starter fireman02
  • Start date Start date Apr 16, 2006
F
fireman02
23
western suburbs, IL
Apr 16, 2006
  • Apr 16, 2006
I installed Flowmaster's American Thunder c-back a couple of weekends ago and had a problem with the driver side tail pipe becoming loose and rattling against the frame where it goes over the axle. I tried adjusting and tightening the c-clamps that came with the kit, but after a couple of minutes of driving it would come loose again. So I ditched the c-clamps and bought band clamps. I thought the problem was solved but yesterday the same thing happened. I know the easy solution would be to get them welded and be done with it, but that makes it a pain in the ass to do work in that area like control arm upgrades and the like. So I was thinking of drilling some self tapping screws in with the clamps to hold the tail pipes in place. Has anyone here tried this?
J
Jack's95gt
443
Huntingdon Valley, PA
Apr 16, 2006
  • Apr 16, 2006
I wouldn't use self tapping screws. That would just promote early rust holes in your tailpipes. Just use heavy duty muffer clamps. Maybe the ones before weren't tight enough.
txstang84
1,639
42
69
Tuscola, tx
Apr 16, 2006
  • Apr 16, 2006
if memory serves, the flowmaster cat-back systems use the clamp on the tailpipe to hang them-correct? my advice would be to take it to a muffler shop and get the hangers welded onto the mufflers a la stock style, and then the tailpipes will have less force dragging on them, therefore less chance of coming loose-then the band clamps would work better for you
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 17, 2006
  • Apr 17, 2006
I wedged pieces of wood in anywhere that looked close Before I tightened down the clamps, then after I pulled the wood out it caused extra clearance in the end.
88306stang
87
  • Apr 17, 2006
I just put the same exhaust on my 93 gt and i had a little problem with the passenger tail pipe. I got my brother to help me and i lined it up made sure it wasnt hitting any thing and he tightened it. When you think you got it tight try to get it a little more and go back and fourth do each side a couple of turns thats what we did on mine and they havent come loose since that day.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
M
  • mnky99
  • Sep 5, 2025
mnky99
M
