GI Joe 97/02 said:What I meant by mail is he has a N/A tune for guys that want a little extra. He can sell the Steeda N/A tune via mail too. It will correct gear ratios and lots of other little things and super tune the N/A car. He did a S/C car via mail...and although he will tell you that eventually you must get to an experienced dyno operator to have the car dynoed...and A/F checked and mail it to him to review...he is so good at it for the basic S/C set up, that once I mailed him the computer of a car I was doing the install on and he sent it back with the tune inside...and then the guy drove 210 miles up there to get it dynoed tuned...not just dynoed...but dyno tuned to finish tweaking the tune if you will.....and he did one(1) pull and said "take it off the dyno...its done...its perfect". Now with a car with heads and intake and cams and all....things get different...but the basic N/A hop - up tune or the basic Supercharger set up.....you can mail your computer to him and he will do it.....and he's very good at it.....
I will have the guy post here and tell you about it.
GI Joe
downsouthman1 said:I wouldn't doubt that but what I'm saying is if I give him my Superchip can he fix my tune there too? & will retuning your chip fix your speedometer or do you need a Speedcal?
i'm in the same boat as you. i'd have to ship mine from Cali to GAdownsouthman1 said:If I send him my comp I can't drive the car. But it'll take forever to get my comp to GA.
cobra killer said:What I would recommend is bolt the stuff on and dyno it..See what the A/F is..The stock tune really needs alot more timing...
Then,if its rich,have someone either tune it on the dyno or send you a chip/reflash to get the most out of the combo.
Chris already had a N/A tune from me ith timing advance..All I did was lean the car out for the new mods..
There's no denying Chris's results.As unreal as they may seem,there were alot of guys around watching the results appear....He had a perfect A/F of 13:0-13:2 when I tuned it 6 months ago.The plenum/filter took him to 11:0-11:5..I simply moved the a/F back to 13.:1 and his results were 20rwhp and 24TQ...No games,thats what it did..
Tim
T&J PERFORMANCE
GI Joe 97/02 said:Isn't it true that it matters whether you want HP or not? A guy that wants HP might say its crazy to buy things like:
Shifter
strut brace
grill delete
wing
cat back
and get zero hp for that money...$800 zero HP. So if you want HP it will cost you those kinds of dollars.
I noticed you have a supercharger on your wish list. Let me point out for you before you do the math and get the sticker shock yourself, that a blower setup for you car will cost you at least $4000. It will yield you about 130 hp if you get the steeda or Cobra Killer tune (and probalby a bit less with some other company's tune). $4000 @ 130 hp is $30.75 per hp. $30.75 X 20 hp is $615. So $25 per HP is about right with a mod car. Keep that in mind in case you decided to add some hp to your car.
timing adjuster, header, mid pipe...they all work out about the same...although there are a few exceptions, like the underdrive pullies.
GI Joe
Man I don't know about that. I think I'm gonna see what the shop who installed my Superchip can do as far as a retune. They'll retune it for me while I wait.ASilver2001GT said:Overnight it.
They should be able to...I think thats what they advertise...at any rate...you need to have tweaked for optimum perf...good luck.downsouthman1 said:Man I don't know about that. I think I'm gonna see what the shop who installed my Superchip can do as far as a retune. They'll retune it for me while I wait.![]()
984.6gt said:If you guys want REAL plenum results go to www.modulardepot.com , they just did a 3 way test between the Accufab, the Dragon, and the C&L, out of the 3 the Accufab was the best by far, and the C&L was the worst.
vrpirata said:So according with modular depot the Accufab plenum of 70mm produce more gain than the 75mm C&L plenum![]()
downsouthman1 said:Correct. But I've heard that the C&L Plenum w/ 75mm TB is the best combo. Who could tell though w/out a true test?
san~man said:How is the test not true? If the size of the TB changed, all of the plenums would most like show a gain over the 70mm one.
