My plenum came in today. Anyone care to give me a quick rundown on how to install this thing? It didnt come with any instructions.
I'm not mechanically inclined at all, but most bolt on parts are easy as pie to install. Just unplug things, install new part, plug things back in.ken44ny said:whats wrong with these idiots not sending instructions.I just spent over $200 on a accufab throttle body and no instructions.
I just reused any gaskets I found. You may want to replace them but my car's been running fine. Put plenum on 1000 miles ago.medik13 said:I don't want to beat a dead horse, but I am just getting around to install my Accufab plenum and 70mm Tb. It came together as one peice with the TB secured, attached and gasketed to the plenum. Are there any other gaskets needed or do I use gasket sealant to mount the upper plenum to the lower? What about the EGR,TPS, and IAC, do they need a gaskets or sealant? Thanks
GT2000JAY said:I didn't need to buy any new gaskets. The only one that they tell you to look out for is the gasket between the upper and lower intake. Just make sure you set the new upper intake squarely on the lower and you should be okay.
My only advice would be to be cautious about the amount of torque you put on the bolts. Remember that the upper intake is secured into metal inserts in our lousy plastic lower intake.
