  • SN95 4.6L Mustang Tech
C&L Plenum Install Question.......
  • Thread starter Thread starter Y2K_MustangVert
  • Start date Start date Jan 7, 2004
Y
Y2K_MustangVert
185
  • Jan 7, 2004
Well the guy in the big, brown truck came today and delivered my C&L Plenum and Tri-Ax shifter!! I started installing the plenum and it went well except for the vacuum line on the rear of the intake. It is causing my throttle cable to get stuck so that it will only open the blade about 1/3 of the way. I rigged it so that the vacuum line is going under it alittle more, but I know it won't work for long. My question is: Has anyone else experienced this, and if so how in the hell did you fix it? This little item coupled to my BBK 70MM throttle body makes quite a difference. After I got done installing it along with my Tri-Ax (which was a breeze and I hear no transmission "whine") I took a short drive and WOW does this thing scream after 4000 RPMs! I actually caught rubber shifting into 4th! This is definately a great mod to get, and I have jumped onto the C&L bandwagon. I gotta give mad props to Ronnie Diaz for all the time that he put into making sure it got here as soon as possible.!
The Tri-Ax makes a world of difference too, and it makes me wonder why I didn't invest in it sooner.
D
DCBigpimpin
130
TN
Jan 7, 2004
  • Jan 7, 2004
I also have a 00 GT but I did not have any problems with my C&L plenum install. I ordered mine from RPM Outlet. But yes this is a great mod. I'm planning on getting an Accufab 75mm TB & C&L Trueflow inlet pipe to replace my BBK 70mm TB & UPR CAI (I have an interested buyer for the BBK). I noticed a huge difference @ ~ 3600 RPMs. I can't wait to complete my exhaust...but I got to get some all season tires. my Falken 451's won't make in the snow & ice.
wms004
2,864
Los Angeles
Jan 7, 2004
  • Jan 7, 2004
i dunno if mine is different since you have a 2000 and mines 01.. but when installing my Dragon Plenum, the metal hose was shorter that the vacuum line goes into, so I was able to pull the hose another 3 inches so that it reached better... dunno if this helps
-wade
HP Addiction
261
Long Island
Jan 7, 2004
  • Jan 7, 2004
Had the same problem when I installed mine. Easy fix: First get 2 washers and put them under the 2 screws holding the linkage assembly. This should lift the cables enough to clear the vaccum line. For extra clearance, I used some black zip ties to move the hose over a bit and out of the way. If you need more clarification just let me know.
Y
Y2K_MustangVert
185
  • Jan 7, 2004
HP Addiction: That is a damn good idea, and also very simple! I guess I was just too damn excited to get it on and go cause some havoc. Thanks Bro!!
HP Addiction
261
Long Island
Jan 7, 2004
  • Jan 7, 2004
No prob, I couldnt wait either and my throttle stuck open lol.
spree
294
los angeles
Jan 8, 2004
  • Jan 8, 2004
i'm having the same problem on my car...the throttle cable got stuck on the vacuum line this morning and I ended up redlining my car for 2 seconds
I just moved the vacuum line over the throttle cable and it looks like the throttle cable is no longer getting stuck on it. Is this a safe thing to do?
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
