C crookman10 New Member May 14, 2007 26 0 0 Feb 20, 2008 #1 Feb 20, 2008 #1 I just bought a c&l 76mm mass air with tube in the instructions it says if not hooking up to stock air box put shroud around filter to block heat. they said it will cause surging idle is this accurate and where can i find a shroud?
vristang 15 Year Member Mar 31, 2005 4,933 101 124 50 Seattle Feb 20, 2008 #2 Feb 20, 2008 #2 the surging idle problem probably isn't due to heat. More likely it's caused by fan wash... Nothing wrong with the stock air box... if you still have it...
