C4 Auto Vacuum Line
  • Thread starter Thread starter pyroman
  • Start date Start date Sep 26, 2009
P
pyroman
480
Ennis, Texas
Sep 26, 2009
  • Sep 26, 2009
I've got a vacuum line at the back of the engine running along the bell housing. I read somewhere that this line was important to make sure the transmission is shifting properly. I can't remember where I got this info, I spent all morning flipping through my shop manual trying to find out about it but failed. What I need to know is where it hooks up. If it helps, I have in dash a/c and it's a 67 that originally had 289.
Thanks
JC Mustang
142
Layton, UT
Sep 26, 2009
  • Sep 26, 2009
There should be a "vacuum tree" screwed into the back of your intake manifold to which this connects. It's likely that your A/C is also connected to this.
P
pyroman
480
Ennis, Texas
Sep 26, 2009
  • Sep 26, 2009
This is what you're talking about right?
Do you know what the other 'nipple' is for? Also I'm not going to use the A/C for now so I'm just got stick a pipe plug in where the A/C line goes.
Also, while on topic. What is this?
I'm thinking it's the vacuum reservoir, but it looks so much smaller than all the vacuum reservoirs I've seen for this car. Anyone know what its from?
Thanks
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 26, 2009
  • Sep 26, 2009
It's a later model maybe Japanese vacuum reservior. Your original was a steel can, which probably rusted so they stuck that in to keep the AC controls working.
JC Mustang
142
Layton, UT
Sep 27, 2009
  • Sep 27, 2009
That's the one.
Any extra nipples would be for any other accessories requiring vacuum. You can cap them if you don't need them.
P
pyroman
480
Ennis, Texas
Sep 28, 2009
  • Sep 28, 2009
I was looking at a vacuum diagram and noticed the vacuum line running off the tree goes straight to the vacuum reservoir and not the transmission vaccum line. Also I had one picture of my old engine with the tree installed and you could see it clearly running to the vaccum reservoir. The other nipple has always been capped. Is there anywhere else it is supposed to attach?
2+2GT
3,333
10
79
Sep 28, 2009
  • Sep 28, 2009
pyroman said:
I was looking at a vacuum diagram and noticed the vacuum line running off the tree goes straight to the vacuum reservoir and not the transmission vaccum line. Also I had one picture of my old engine with the tree installed and you could see it clearly running to the vacuum reservoir. The other nipple has always been capped. Is there anywhere else it is supposed to attach?
The modulator on the back of the transmission should be attached directly to manifold vacuum, NOT any vacuum reservoir. A reservoir would interfere with proper reaction of the transmission to changes in the engine.
P
pyroman
480
Ennis, Texas
Sep 28, 2009
  • Sep 28, 2009
Thats what I figured. I suppose I'll just hook it up to an appropriate vacuum source on the carb.
2+2GT
3,333
10
79
Sep 28, 2009
  • Sep 28, 2009
You'll be better off putting the brass vacuum fitting back on.
P
pyroman
480
Ennis, Texas
Sep 28, 2009
#10
  • Sep 28, 2009
  • #10
I plan too because I need vacuum for my HVAC system. I suppose I could just run it off that capped nipple then.
AC vacuum line in firewall
  • Bobburnett1954
  • Jul 1, 2024
1996 - 2004 SN95 Mustang -General/Talk- Jul 1, 2024
Mcmahst
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
  • mnky99
  • Sep 5, 2025
mnky99
M
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
