C4 bellhousing/flexplate removal and install pics.
stephen4785
321
Fort Worth Texas
pics fixed-C4 bellhousing/flexplate removal and install pics.
Well Its taken me a week to do cause of all the rain weve had.Ill write a brief description of whats going on. Heres the pics. Sorry I dont have any after pics because after I removed my flywheel it started raining. I put up all of my toold but forgot the camera outside. Needless to say digital cameras dont like water. Oh and I know the bottom of my car isnt in showroom floor condition. Its a work in progress and its my one and only car.
attachment.php
theres 6 bolts holding the bellhousing to the motor.
attachment.php
remove the four nuts and u bolts. Use a screwdriver and pry the driveshaft toward the motor. Once its loose wrap some tape around the ujoint because the caps will fall off.Before sliding the driveshaft out of the tranny place a drain pan under the tailshaft cause fluid will run out. Place the driveshatf out of the way. Get some plastic (a sandwhich bag) and put it over the whole where the shaft came out of and wrap tape around the bag to seal the end so fluid wont get over everything.
attachment.php
remove the 2 bolts holding the starter on and then remove the 1/2 nut holding the starter cable on.Remove the starter.
attachment.php
remove the kickdown linkage by removing this c clip.
attachment.php
remove these 2 cooler lines from the tranny.Its not required to remove them from the radiator. Wrap some plastic around the tube ends and tape them up so no dirt gets inside.
attachment.php
attachment.php
remove the shifter linkage from the shifter by removing the cotter pin. Remove the 7/16 bolt from the speedo cable and pull the cable out.
attachment.php
attachment.php
attachment.php
There are 4 nuts holding the torque conv on. I used a 1/2 socket wrench a 6 inch 1/2 drive extension with a socket on the front crank bolt to spin the motor over so i could remove all 4 bolts. Remove the dipstick by pulling it up. Disconnect the vacum hose going to the vacum modulator.
All you have to do at this point is put the jack under the tranny,remove the tranny mount, pull the tranny back and drop it down. Since the previous owner has a custom H pipe made I had to cut the exhaust out to get the tranny out and in.You may not have to depending on your setup. While the tranny is out you might as well replace the filter. If your like me and manage to spill most of the tranny fluid on the ground your gonna have to put in new fluid. Iv probably left out some minor details so youll probably have to remove something that I didnt list. I have alot more pics but I cant post them due to the size of all of them.If you want them then pm me and Ill email the, to you.
.All of the pics are self explanatory I think. I didnt have enough room to post all of them.After unbolting the torque convertor (there 4 nuts holding it,you have to crank the motor over with a socket wrench) all you have to do is put your jack under the tranny and pull it back then drop it down. Theres 6 bolts holding the flexplate on and a round ring. If you want to save you some time then mark where the counter weight is on the old flexplate and reinstall the new flexplate and ring the same way the old one came off..
Great writeup for those that have never done it! A couple of things others might want to consider: you can buy a rubber plug that fits in the tailshaft of the tranny to prevent fluid spilling during removal, (N.P.D. sells one for $3.50). To make things safer, you can purchase a trans. holder to go on your floor jack to keep the unit from tipping and it will also allow you to tilt it for easier removal. I bought a cheap one at Northern Tool. Finally, use a flare nut wrench to remove those cooling lines or you risk stripping the bolts.
For those not familiar with them, they replace the saddle on your floor jack and have adjustable sides and front to fit different tranny's. They also have a safety chain that loops over the tranny to keep it from falling. The sides and front go up against the trans. pan to hold it and there is a tilt mechanism built in.
