C4 Flexplate question
  • Thread starter Thread starter brands5.0
  • Start date Start date May 19, 2005
brands5.0
577
miami ,florida
May 19, 2005
  • May 19, 2005
I have a C4 In my car and i bought a super expensive PA 50 oz. I am now building a "0" 364 can i just cut off the counter weight. it makes sence i am looking at a 28 oz and the 50 oz and the weights are in the sam place ?? seems like i cold just cut it off and it would be fine
T
tjm73
2,418
Rush, NY
May 19, 2005
  • May 19, 2005
Let's see, you're spending several thousand dollars on a new engine and you want to just cut the weight off that flexplate and go with it?
Not to sound liek a jerk, but....
Ummmm....... no, I wouldn't do that if I were you. At the least take it and have it done by a mahine shop where they can reballence it after the weight is removed to be sure it's zero balence. Or sell it and buy a zero balence flexplate.
You said it's "super expensive", but a new flexplate is like $225 and your block alone was about $2500. Plus machining, the cranks, rods, pistons, etc....
Does it make sense to skimp on a $250 part when your spending several thousand? Not to mention it's a pretty importent part. Vibration will kill an engine and seriously hinder performance.
brands5.0
577
miami ,florida
May 19, 2005
  • May 19, 2005
I know i shoud end up buying a new on but i had a he11 of a time finding a flex plat that fit i have 2 50 oz one cost like 150.00 and the other i just bought last month set me back 279.00 the weights are fust tacked on i just wanted to see if any one had done it befour
thumper460
3,022
Orange Park , Fl
May 19, 2005
  • May 19, 2005
I had to see this!! HELL NO!! you cant just cut the counterweight off!! Get the correct flexpalte and have it balanced with the rest of the assy..... you DID get the rotating assy balanced... didnt you??
Just me.......................
Thumper
brands5.0
577
miami ,florida
May 20, 2005
  • May 20, 2005
The motor is not built? just trying to see if i could reuse an existing flywheel.. I have a PA C4 and when i installed it the flexplate i had wouldnt quite fit there was at least a 16th gap so pa set me one that was a 16th deeper if i have the same problem with my new motor ill have to buy another custom one.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
