C4 Front Pump
  • Thread starter Thread starter 32DeuceCoupe
  • Start date Start date Dec 12, 2005
32DeuceCoupe
  • Dec 12, 2005
I am in need of an oil pump(front pump) for my 1966 Mustang C4 transmission. I am not sure the year of the tranny, as it is not original. I am told that the pump is installed with just 4 bolts. I can find the pump, but I need to know if I buy it, could I install it myself? I am very capable with normal repairs and engine rebuilds but haven't messed with an automatic transmission before. It seems to be a straight forward install but I just wanted you guys' input. Thanks.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 12, 2005
  • Dec 12, 2005
Yes. I did it years ago and I knew nothing about trannys.
brianj5600
1,964
Middle TN
Dec 12, 2005
  • Dec 12, 2005
Changing it is not too hard. The hard part is freeing up the pump from the case. The pump is the most well oiled part in the whole trans, how do you wear one out w/o frying clutches?
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Dec 13, 2005
  • Dec 13, 2005
Fairly easy job. I did a writeup on it a few years ago (with pics) and you can find it here: http://www.geocities.com/dennis_2685/frtpump.html
A shop manual would also be useful and is recommended.
The only problem I had was that I didn't pay attention as to where to place the shift arm when reinstalling the valve body. It will make sense if you look at it in advance.
If you have problems, just holler.
Good Luck.
32DeuceCoupe
  • Dec 15, 2005
Thanks for the replies guys. The pump does not need to be changed, just installed. The transmission was rebuilt, but the pump was never installed. Now a pump has to be installed. I guess that this is the only way to install the pump(referring to your website)? I was hoping to remove the bellhousing, input shaft, and then just install it. Of course I am sure it can't be that easy, what was I thinking! I will definitely ask for help if I get stuck. Thanks again for the replies.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
R
First project car and first time learning on cars
  • Rustang jr
  • Oct 2, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 6, 2025
Rustang jr
R
