Okay, so the C4 transmission from my '66 has been leaking lately out of the gap in the inspection cover. It was leaking from inside the bellhousing so my first guess was that the front pump seal blew out. I pulled the engine out this weekend to replace the front pump seal but it looked great. The seal was still on square and looked to be in good shape but i could see how the transmission fluid was leaking down the inside of the bellhousing where the front pump seal is.
Well, I went ahead and took out the seal to replace and found a bushing loose around the shaft. I don't know much about transmissions so I don't know specifically what this part is. It was the same diameter as the seal and had a kind of a channel running at a 45 degree angle on the inside. The bushing was bent out of shape but didn't show any unnatural wear. I really dont know what this means. It wasnt leaking out of the seal so the bushing must be to blame?
Should I just replace the bearing or do you guys think there is a bigger problem?
Sorry about having no pictures.
