C4 Question.. PLEASE HELP!!!
  • Thread starter Thread starter red89stanggt
  • Start date Start date Sep 26, 2005
red89stanggt
974
Bernville, Pennsylvania
Sep 26, 2005
  • Sep 26, 2005
Hi all..
I just bought another 5.0 tonight, and on the way home i was driving probably got on it about half throttle and went from 1st to 2nd and it shifted fine then just went clunk and that was it.. I dont have any gears anymore, but park works.. I checked the fluid and it was empty. I filled it and still nothing.. T here is a whining noise coming from the transmission now. It has a built c4, 3200 stall, and a manual valve body.. I wasnt even on it hard and it crapped out.. what gives?
PLEASE HELP ME SO I CAN DECIDE WHAT TO DO WITH THE CAR!!
red89stanggt
974
Sep 26, 2005
  • Sep 26, 2005
ttt
J
JB66
565
New York
Sep 26, 2005
  • Sep 26, 2005
1 on the road C4 minus fluid = 1 fried pump
Pull it out and rebuild it. There's metal shavings all through it, I'm sure.
Sorry...
red89stanggt
974
Sep 26, 2005
  • Sep 26, 2005
What all is involved with rebuilding it? Its strange that it would just instantly quit while giving no prevois signs that anything was wrong.. It just stopped and that was that
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Sep 26, 2005
  • Sep 26, 2005
first thing you need to do is take those wheels off, take the c4 out and send them both to me immediately. something is definetly broken in the tranny. check all the linkage and make sure its all intake. pull the pan and check the filter for burned up band material
red89stanggt
974
Sep 26, 2005
  • Sep 26, 2005
I'll take a look tomorrow.. I tend to think that the converter went bad.. If the transmission isnt engaging what would be making the noise coming from the transmission.. It is making the noise even in park..
ExplodingGopher
517
The mistake on the lake (Ohio)
Sep 27, 2005
  • Sep 27, 2005
sounds to me like the front pump is gone, simple rebuild.
red89stanggt
974
Sep 27, 2005
  • Sep 27, 2005
What all is involved with fixing that?
rd
3,316
63
109
Ocean Springs MS
Sep 27, 2005
  • Sep 27, 2005
Sounds like a possible major prob, started by a lack of fluid.
A C4 will quit shifting or shift poorly if it is low on fluid, and if you refill quickly, and dont let it burn by spinning dry, it will live again.
Probably killed something like the pump, from running dry, and most likely the clutch seals on the forward clutch, etc.
It could be just a stuck valve body, at the 2-3 shift valve. As a long shot, you could pull the vb and clean the 2-3 shift valve and see if that fixes it. But a cleaning and freshening , or thorough rebuild seems inevitable.
red89stanggt
974
Sep 27, 2005
#10
  • Sep 27, 2005
  • #10
ok thanks! It just seems odd that it shifted perfectly fine and then quit.. Like I said earlier it gave no signs of quitting on me..
nosmatt
1,356
Bass Lake, Ca
Sep 27, 2005
#11
  • Sep 27, 2005
  • #11
pull it out, and tear it down.
this is NOT an aod, this takes about an hour, to have it out, and disassembled........or, send the car to me, and the pink, ill send ya 500 bux
really tho, this is an easy to work on trans, and it is pretty light.........rebuild kits for em are about 50 bux, and pumps (rebuilt) run about 40 for em.......sounds like you toasted the pump, it will need a complete teardown, and cleaning better than you can imagine. expect all this to take about 4-6 hours.
red89stanggt
974
Sep 27, 2005
#12
  • Sep 27, 2005
  • #12
Where do I get the parts to do it?
W
webshot
738
Yay Area, California
Sep 27, 2005
#13
  • Sep 27, 2005
  • #13
:OT: redstang your avatar looks like my neighbors uncle....lol. I just purchased a ford manual that is like a chiltons on steroids. And it has a good section on trannies. You may could invest in one of those. I am not at home right now but I think it is made by "Haynes" or something like that.
red89stanggt
974
Sep 27, 2005
#14
  • Sep 27, 2005
  • #14
Is it for ford transmissions? I have a Hayned for the ford 87-93 Mustang, but there is no help for a C4..
red89stanggt
974
Sep 27, 2005
#15
  • Sep 27, 2005
  • #15
ttt
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
