c4 to t5 conversion
  • Thread starter Thread starter 1967stang302
  • Start date Start date May 2, 2005
1 of 2 Next Last
1967stang302
87
Orange County, CA
May 2, 2005
  • May 2, 2005
First I'll tell you what I have. I have a 67 mustang coupe with a brand new 302 pushing about 280 RWHP. I have a C4 in it right now and the shifts from 2-3 are starting to get very screwy so I'm trading up. I've decided to put in a t-5 world class and have been looking around. I have looked at the darhorseperformance swap kits but they are a little pricey. Can anyone tell me what I need to do this. Obviously I know I need:
transmission
T5 cross member
New bell housing
shorten the drive shaft
clutch and brake pedals
t5 conversion kit from someone like cal mustang or mustang depot.
What else? I have heard I have to shorten the yolk. I'm also wondering with the goal of 400RWHP is the world class t5 going to hold up? I am on a budget of about 4G's for the whole thing including installation, so I'd also like to know of budget cuts I can make for tollerabley used parts instead of new. Any tips or info from other people who have done this would be appreciated. Also if there is a specific model of the T5 I need to put in to fit my 302 as opposed to one that would fit a new engine, please post.
For those that will flame me, I have searched the forums but did not find everything I want to know.
stangman67
294
connecticut
May 2, 2005
  • May 2, 2005
Everything you need to know:
www.moderndriveline.com
06cobra
146
  • May 3, 2005
On a 68 Fastback we did NOT need to shorten the driveshaft, toploader and C4 drive shaft are the same shaft in the carl (did a C4 to Toploader swap years ago, now its a T5).
Though it is a GT, we had a flywheel issue, original was 164 rather then 157 tooth that fits in the T5 Bellhousing (164 DOES NOT fit).
Rest of it is rather straight forward, did it on the floor in a double garage over a weekend.
G
gjz30075
250
Roswell, Ga
May 3, 2005
  • May 3, 2005
Type of clutch linkage is another decision. Assuming you're going with a T5 bellhousing (you can use a toploader bell but then you'll need to use the equalizer bar clutch linkage and I don't think you want that), you can use either a cable or hydraulic. Both have their issues and strengths. There are plenty of kits on the market for both, too.
CornerCarvin67
246
  • May 3, 2005
One thing you'll need for sure is PATIENCE.
I've been working on my swap for a month now... and with my kids or other interrupting me along with waiting for parts and little gremlins popping up.
You'd be smart to spend alot of time on line reading.
If you're going solo... don't expect it to be easy. But I don't want to scare anyone off either. I'm at about 90% and I'm pretty pumped up about it.
Good luck.
06cobra
146
  • May 3, 2005
Actually the Online reading is all a little False, the truth and internet seems NOT to go hand in hand.
I found that the Premade crossmember is what sped my process up, and the use of a good tranny jack. (floor model) I had to lift the car up about 24" off the ground to use it, but was well worth it.
STSFCTN67
450
Denver, CO
May 3, 2005
  • May 3, 2005
T5 cross member
New bell housing
Don't get a T5 conversion kit -
Get a World Class T5 or TKO
Used 5.0 bellhousing w/the T5
New Flywheel from Summit or Jegs that is both 28oz and accepts a late model King Cobra Clutch kit.
Get a hydraulic JMC clutch kit so you never have to worry about a cable getting toasted on the headers
get a new C4 tranny mount
Do you have power brakes now? If not, something you may want to consider since you will have the master cylinder out anyway when you change the pedals out.
See Signature...
LMan
1,246
Mom's basement
May 4, 2005
  • May 4, 2005
make sure your flywheel matches your engine imbalance.
CornerCarvin67
246
  • May 4, 2005
Right... don't mind what people may say on the internet... cuz we may just be "false". Go ahead and rip out your C4 and just wing it. Who needs research?? You may finish up by the end of the year....
06cobra
146
#10
  • May 4, 2005
  • #10
Truth man, some of the stuff listed on the net is either false, only half the full picture, or just hearsay.
and you can't say you haven't run it to this.
NOTHING ANYWHERE said anything on Moderdriveline's site about possible different flywheel sizes...............imbalance factor yes, but not physical sizes!!!!!
and they are supposed to be the ONES.
Cost over run, if that and a proper starter wasn't budgetted for!!!!
So yes DON'T believe everything, its only half the story!
1967stang302
87
Orange County, CA
May 5, 2005
#11
  • May 5, 2005
  • #11
So this is why I wanted to post this thread. My C4 is crapping out and I need to replace it in the next 2 weeks. I don't want to buy a MDL or DHP kit if I can just get a list from one of you guys and get everything separetely if it is cheaper. and I have heard that I do have to shorten the drive shaft, I don't have to shorten the drive shaft, there are specific T5 models with shorter input shafts that make it so I don't have to change the driveshaft, getting confused... clowns are coming for me... clowns are coming for me..... MOMMY! Anyone that can give me a full list, I am not doing the work myself, but I am going to have to collect everything I need.
DHP - Darkhorseperformance.com
MDL - moderndriveline.com
MrBobMarley
460
Ft Myers, FL
May 5, 2005
#12
  • May 5, 2005
  • #12
t5
bellhousing
28 oz flywheel 157 tooth
c4 trans mount
crossmember
pedal assembly(I got all my stuff from mustangsteve. $484 COMPLETE kit with pedals, support, booster, adjuster, cable etc)
hydraulic or cable clutch (two most popular)
shifter
shift boot
lower shift boot
shift knob
arp flywheel bolts
arp bellhousing bolts
driveshaft (I had a new one built $180, long story)
That should be about it, but I'm sure I missed a couple things.
1967stang302
87
Orange County, CA
May 6, 2005
#13
  • May 6, 2005
  • #13
Has anyone purchased the darkhorseperformance kit or the moderndriveline kit for C4 to T5 conversion? If so which one and how was the customer service and shipping times and the product? I'm thinking that I' just going to buy a kit since it is easier, anyone have any ideas?
LMan
1,246
Mom's basement
May 6, 2005
#14
  • May 6, 2005
  • #14
something on the Net wasnt the full story? OMG, my world is shattered
your C4 starter will work fine. The 5.0 flywheel is 10.5" diameter and the one to use. But that's JMO
W
W!CK3Dx65
#15
  • Jun 24, 2009
  • #15
thank you
this helps alot
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jun 24, 2009
#16
  • Jun 24, 2009
  • #16
Good idea.
transmission
T5 cross member
New bell housing
Well, new to you. Get the C5D OEM bell
Not in my experience.
Yup. Used or new.
Why? The above list is much of what you need. Besides, you're better off with Glazier's
Yoke. Nope. The C4 yoke you have now will fit the T5.
Plus:
clutch assist spring
assist spring bushings
assist spring bracket
67-68 clutch pedal rebound bumper
upper clutch rod
clutch rod bushings
clutch rod firewall seal
equalizer
equalizer spring
equalizer frame pivot
equalizer engine pivot
lockwasher
pivot balls
pivot ball clips
pivot felt seals
equalizer lower spring
lower clutch rod
release lever boot
release lever
release bearing
clutch assembly
pilot bearing
flyuwheel
manual rear engine cover
T5 OE style shift lever
T5 OE style shift knob
OE style shift lever boot
T5 OE style shift lever boot retainer
bolts
I have put many of these kits together.
Forever, unless you beat the snot out of it.
I am on a budget of about 4G's for the whole thing including installation, so I'd also like to know of budget cuts I can make for tolerably used parts instead of new. Any tips or info from other people who have done this would be appreciated.
Well, I'll point out that Glazier's has done many of these, and they'll actually answer your questions over the phone.
No, the "World Class" new, used, or rebuilt will do.
tx65coupe
Jun 24, 2009
#17
  • Jun 24, 2009
  • #17
2+2GT, when you answer questions like that it makes it hard to see your answer or reply. You should consider making your text blue or something. I do like how you respond though. I didn't mean to sound condecending.
As for the original poster.
I have a late model bellhousing with my T5.
I used a Modern Driveline crossmember and clutch cable kit.
I had to shorten my driveshaft (actually got a custom aluminum one) but I also have a 9 inch rear end.
This setup works well together.
I agree that you need to check that the flywheel is the right balance for the engine.
2+2GT
3,333
10
79
Jun 24, 2009
#18
  • Jun 24, 2009
  • #18
How's that?
R
rebel65
363
SF Bay Area
Jun 24, 2009
#19
  • Jun 24, 2009
  • #19
that's great
tx65coupe
Jun 24, 2009
#20
  • Jun 24, 2009
  • #20
2+2GT said:
How's that?
Thats great makes it much easier to read.
1 of 2 Next Last
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 2 3
1974 - 1978 Mustang II Talk & Tech Monday at 7:42 PM
LILCBRA
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
