C4 to T5 Question
XXBULLETSXX
301
Kannapolis, NC
Ok I know I have to do a jumper to get the neutral safety switch to allow the engine to run. But what exactly do I jump? Do I cut the wires and splice the together? That seems like to easy of an answer which will light a fire under my dash.
Help needed, putting engine in tomorrow and I really want to be able to start it up!
Just thought I would post what I found out on this in case it would help someone else.
I had a set of connectors which came from my tranny and hooked up into my Neutral safety switch and I knew one was the NSS and the other was the reverse lights. One connector was red'ish and the other was like a grey or light blue. For my car the correct connector for the NSS is the Grey/Light Blue connector.
Help this helps some one in the future!
Oh BTW, nothing bad happens if you jump the wrong connector out of those two.
