The price on the top loader will vary depending on where you buy it, what speed it is, and if the seller knows what they got. I see 4 speeds go for around $400 or so out here in CA, but they are not cleaned up ones. You can do a hydraulic set up on a top loader, which I would recommend doing as I hate the clutch linkage. The price to allow your car to use a manual will be in the form of a new tranny crossmember, and a new brake pedal along with a clutch pedal. I think that you’ll also need a new slip yoke because of the different spline count (I think 4 speeds are 25 spline, so count your to find out). The cost of the hydraulic kit all depends on where you get it. As for the headers, well you'll have to ask the manufacture on that one. You will also need a new flywheel, which means that you'll need a new starter, because I am pretty sure they had different tooth counts.
