C4 transmission ?'s
  • Thread starter Thread starter GTCobra90
  • Start date Start date Aug 17, 2008
G
GTCobra90
29
  • Aug 17, 2008
should i be able to just pull the input shaft out of the tranny while it's sitting there? i got the transmission from someone who said it was built. i have hade the tailshaft housing of and everything was brand new so im not doubting the rebuild but the converter he gave me im can't get the converter to match up with the input shaft splines. the shaft has 26 splines. the converter i was told is a hughes 10 1/2" 3500 stall but it has no #s on it so i can compare anything.
thanks guys any info will help me
88mouse
630
Mooresville nc
Aug 17, 2008
  • Aug 17, 2008
yeah the input shaft will come right out. Just make sure you get it all the way back in.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Aug 17, 2008
  • Aug 17, 2008
i cant remember if the C4 has an intermediate shaft or not but*** if it has an intermediate shaft like the AOD it will pull out of the center of the actual input shaft. make sure that stays in the trans when it goes in the car... also as far as the converter goes.. make sure that intermediate shaft is ALL the way inserted into the input shaft THEN install the converter by pushing slightly WHILE slowly turning the converter it should "fall into place"
G
GTCobra90
29
  • Aug 17, 2008
ok
Thats good that the shaft is capable of sliding out then. but shouldn't i be able to take just the shaft and slide it in the converter?
F
C4 Transmission
  • Fri Guy
  • Jan 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
LILCBRA
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
