Just an expereince "look-out" concerning C-4s
This is particular to reverse valve bodies!
The reverse direction utilizes the high band in the tranny (3rd). In the reverse valve body it is possible to continue to shift past the fluid ports in the transmission. If you do that, it ports the fluid to reverse. With mechnical linkage, properly set, this over-shift cannot happen. HOWEVER, a cable shifter, a-la B&M hammer can easily stretch and be mis-adjusted and eventually lead to an over-shift condition.
This happened to me going forty miles an hour @ 730 AM in Monday morning traffic. Out of the blue about 5 seconds after shifting into 3rd, the rear wheels locked and I literally did a 360 missing on-coming and same direction traffic by the grace of God.
Not only did I have an internal shift limiter (metal stop) installed in the tranny but I re-ground the detents on the stock shifter, went back to stock mechanical linkage, and will not go back to cable sifters.
