  • 2010 - 2014 Specific Tech
CAI and Disconnect
  • Thread starter Thread starter retiredf5
  • Start date Start date May 2, 2012
R
retiredf5
61
Delaware
May 2, 2012
  • May 2, 2012
Have a 2012 GT 5.0.
Over the weekend, will be installing a CAI. Before doing the install, instructions say disconnect negative terminal to battery. For the 45 minutes to do the install, what do I lose as far as settings go? Radio stations? Security settings, Computer settings etc etc???
I bought a Computer Memory Keeper which plugs into the cig lighter/power plug in the car. The Keeper has a 12 volt battery attached that when plugged in, is supposed to keep all memory setting from disappearing. Since I have to disconnect the MAP and re-connect it after the install, is there any power flowing thru it from the Keeper battery that might cause a problem or is all power to the MAP controlled via the ignition switch . . .which is always in the off position during the install??
Anybody who has done a CAI install would appreciate your thoughts.
bigb427
128
Las Vegas, NV
May 3, 2012
  • May 3, 2012
When doing any modification or repair that affects the air/fuel ratio the computer keep alive memory must be reset to ensure the new parameters are relearned properly. This means you will disconnect the battery and loose all your settings on your radio and what not. Using a memory keeper will not clear the computer memory.
There are two ways around loosing your settings if you are concerned with this. If you have a capable scan tool you can select reset keep alive memory on it. Be aware that selecting an option to clear codes will not clear the computer memory. The other option is to remove the computers memory fuse. I believe that is fuse number 23 in the under hood fuse panel on your car.
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
1991 3g alternator not charging
  • BigShowJoe
  • May 12, 2024
3K
Fox 5.0 Mustang Tech Mar 30, 2025
Chuckster101
C
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Electrical SUDDENLY FUEL PUMP SHUTTING OFF RANDOMLY
  • PonyGTrider
  • Nov 7, 2023
6K
Fox 5.0 Mustang Tech Feb 10, 2024
Mindseye007
