CAI install, rough idle....Help
Can someone please help me. I just installed a fenderwell CAI from ebay and my car now seems to idle a little rough. It sounds like a surging noise. How can I resolve this issue? I dont think it the Maf or Iac needs a cleaning since it ran fine with my stock induction, but I could be wrong. Please respond. Thanks
Make sure the MAF is installed in the correct orientation. Make sure that the connections are clean and properly attached.
Your new filter have came oiled from the factory. You likely got oil on the MAF. Try cleaning it with keyboard cleaner.
Make sure that the the intake track is air tight from the MAF to the throttle body.
Not much else can screw up your idle after a CAI install.
I think your on to something with the oil. My filter said oil before using so I oiled it up but I let it sit for about 45 min. Whats the reccomended way to clean it. Can I just spray some brake cleaner or do I have to use the Q tips as well?
The filter, NOT THE MAF! LMAO
DO NOT OIL YOUR MAF, or clean it with soap and water. Do not use brake cleaner.
Use compressed air. It's the ONLY safe way to clean it. Spray it out with compressed air for a good amount of time, and if it was oily, that'll fix it.
If not, it's most likely one of the other issues I suggested.
Good luck.
Why not brake clean? The ingredients look very similar to that of electrical contact cleaner, which seems to work well. :shrug:
You can clock the MAF to see if it helps. Did you index the ACT (I doubt that is the issue, but who knows, and indexing it is the way to go anyhow).
Good luck.
Spray it down with a good amount of K&N cleaner, NOT OIL. Let it sit for about 10 minutes so the cleaner can do it's thing. Then rinse it with a hose (don't use any water pressure) form the inside out, so you don't drive particles into the filter. Let it sit out for awhile to dry, then spray on the k&n oil. Spray one pass only, don't spray the chit out of the same area. Let it sit again for about 10 min.
Make sure maf is plugged in, no leaks with any fittings, ect.
1.) Make sure your maf is clocked, straight seems to work best for me.
2.) Make sure your ACT sensor is lined up right so the air is blowing thru it (little black sensor that goes in there)
3.) Clean your maf, unbolt the top piece with the security bit, take it out, get a q-tip and some throttle body cleaner, spray the TB cleaner on the q-tip and gently clean the wire you see on the MAF. I dont care what ppl say on here 100s of people do it this way and it works GREAT. Blowing air wont actually get the greasy residue off! Be gental and let it dry after.
That will help a lot. Since your CAI is new and you oiled her up good (prob too much) you will more then likely have to clean maf again in a weeks time.
Said another way, one wants the actual element (wire) to be in the air flow path, not shrouded by the 'towers' which support the wire. Do you want to kick a field goal through the uprights from the 20 yard line (middle of the field) or from the sideline? Same deal.
RedStallion43 said:
OOO ok gotcha, how do i make sure its lined up, I got to take it apart again and look through?
Well yeah, that is the easiest way to do it.
Disconnect the tube from the MAF, and look in. Make sure the inner element is not blocked. You will see what I mean.
and when you are done, you can put a mark on your intake tube, and another on your IAT sensor. That way, you will always know when it's lined up.
Scott
