calculate compression ratio
Mustang_Punk
224
Sac, Ca
So I have a 306 that SUPPOSEDLY has 10.5 to 1 compression.
The heads are 55cc.
what CR would I have with pistons that are supposed to get 8.21 to 1 on a 63cc head?
im trying to find a decent forged piston to lower my CR so I can install a S-trim without fear.
Current combo:
- AFR 185 heads
- Edelbrock Performer or Holley SysteMAX intake (its got a cobra right now)
- E303
- 1.7RR, may put the 1.6's back on
- SN95 Fuel Rails
- 30lb/hr injectors
- 195lph pump
Want to add: S-trim with 3.33 pulley and 6.87 crank pulley
and the necessary pistons to achieve a boost happy CR
I can tell you that a 8cc difference isn't going to make-up for a 10.5 to 8.21 difference.
In my signature, you can click on the heads, intake, cam, compression link and at the bottom it has a nice static compression calculator that you can plug in numbers.
Even with boost, I would get a 'piston' that allows more compression that that, maybe around 9-9.5:1...
88mouse
You can always get a an .080 head gasket to throw on there. Will drop it down right to where it needs to be.
We been thing about doing this to my buddies 11to1 347 and puting a blower on it.
You do not want to do this if you can avoid it, this is only a band aid. You will decrease the efficiency of your motor as you will start affecting the "Squish" in the combustion chamber, which is how the motor helps induces eddies and swirl that help burn all that fuel/air that are drawn into the cylinder.
Walz
