Caliper bracket issue
  • Thread starter Thread starter Richard corkum
  • Start date Start date Jun 30, 2019
R
Richard corkum
Nova Scotia
Jun 30, 2019
  • Jun 30, 2019
Did the 95 mustang rear disc to 90 mustang. Can’t use the 95 caliper brackets as they are about a 1/2 inch off so I have to use washers to bolt the caliper on so it lines up. Is there a special bracket made for this swap? Please advice! Thanks richard
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jun 30, 2019
  • Jun 30, 2019
I'm guessing you are using sn95 lenght axles and fox offset brackets or vice versa.
To answer your question, yes they do make brackets, but to recommend which once depends on what parts you are currently using.
R
Richard corkum
Nova Scotia
Jun 30, 2019
  • Jun 30, 2019
I’m using 90 8.8. 95 axles, brakes and brackets the caliper is about 1/2 off so I used washers but I don’t like that.
HotFox
1,069
701
164
SE Michigan
Jun 30, 2019
  • Jun 30, 2019
I did it with the stock brackets mounted on the inside. You have to notch the bracket and radius the area of the bracket that sits around the tube to clear the weld. This was a fox 8.8, SN95 caliper bracket and custom Moser fox length 5 lug axles that have the correct hat diameter to accept the SN95 rotors. There was shims on my setup.
R
Richard corkum
Nova Scotia
Jun 30, 2019
  • Jun 30, 2019
So you cut the brackets and put them on the inside?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jun 30, 2019
  • Jun 30, 2019
That setup should work as is an not be off at all.
How exactly is it off? Does the axle stick out too far or not far enough?
HotFox
1,069
701
164
SE Michigan
Jun 30, 2019
  • Jun 30, 2019
Check out my build thread I think I show some pictures on how I cut them. There also should be some threads on this subject. I for sure was not the first to do this.
R
Richard corkum
Nova Scotia
Jun 30, 2019
  • Jun 30, 2019
It is approx 1/2 too long
R
Richard corkum
Nova Scotia
Jun 30, 2019
  • Jun 30, 2019
Not sure how to find it
HotFox
1,069
701
164
SE Michigan
Jun 30, 2019
#10
  • Jun 30, 2019
  • #10
It's in my signature but I think you only see it on a PC not mobile...any way
Link
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
28,143
10,762
213
polk county florida
Jun 30, 2019
#11
  • Jun 30, 2019
  • #11
This may be some help too.
Brakes - The Ultimate 4-lug/5-lug Brake Conversion/upgrade Thread
Starting this thread with the hopes of reducing the number of 5-lug or general brake upgrade threads that have been appearing on the forums since most of the major brake conversion sites have gone down. This thread will be strictly informational, and any off-topic banter or user specific...
www.stangnet.com
Wayne Waldrep
Before I post a pic, do you have one of yours?
20+ Year Stangneter
Apr 14, 2003
1,338
659
143
Cuba, AL
Jun 30, 2019
#12
  • Jun 30, 2019
  • #12
View: https://www.youtube.com/watch?v=9i8rC9fffnA
This has some good info and the above thread is very thorough.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jul 1, 2019
#13
  • Jul 1, 2019
  • #13
Time out. Before you cut anything, answer one question.
How is it off. Does the axle stick out too far, or does it not stick out far enough?
If you stuck a set of 95 axles, brackets and calipers on a 1990 rear, it should all bolt up fine and nothing should be off. We should really identify the issue here before setting you off to cut parts up, or buy new parts.
Do you have photos?
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
AeroCoupe
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
