HELP caliper removal problem lowering springs
I knew it was too good to be true. Am installing new springs and shocks, and on the last wheel i've got a caliper bolt thats stuck dead. Is there any way to Replace spring and shock with caliper in place????
The PB blaster is a good place to start, but if you have to removing the brake line isn't that big a deal, just bleed the brakes after (shouldn't even get THAT much air in there if you block the hole off right when you take it out).
